Question about Intel Motherboard
Power supply ok but mother board is not working
  • Intel Master
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Posted on Aug 30, 2010
How to check processor working
Hello dear,
If your motherboard power lamp will be off/on automatically, it could be related to bad supply unplug all connection and plug it again proper if still you have same problem then you can try another OK power supply
Jun 08, 2012 | Gigabyte GA-M51GM-S2G Motherboard
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Model # TH-42PX80U tv was on when a storm hit 'lightning' , on lite only blinks... is it a fuse ? or mother board?
You are better off replacing the power supply board. Usually the mother board will output a power ok signal to turn on the TV only when the power supply is working correctly (all voltages are within specs), similar to a computer, having said so, if you have the schematics you can verify those voltages being output from the power supply upon depressing the power button. The +5v stand by voltage is most likely ok, since the mother board is at least providing you with the blinking light. It is the +12V and +24V which are not being output, along with any other auxiliary voltages. I would suggest either having a replacement board (power PCB) installed or otherwise feeding the needed voltages by substituting those missing ones with a variable DC power supply, just to verify it. Follow above only if familiar with electronics and electricity. safety first!.
http://www.HDalacarte.com guy audio/video/computer technician for over 30 years
May 26, 2011 | Panasonic TH-42PX80U Plasma TV
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
I have an AsusP5P 800 mother board and the unit won't power on.
I had a very similar issue like this, how many RAM modules do you have installed? if you have 2 DIMM installed try removing the memory on at at time(try interchanging the RAMS), see if turns on. if not might be the motherboard itself thats possibly defective.
Feb 14, 2010 | ASUS P5P800S Motherboard
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Inspiron 6400 DC input fault
please remove the power supply pin from the mother board short the pin witres colured green and black if the power supply is working then there is no problem with the power supply check ur memory card to if the pwoer supply is working iff its ok and still not working contact a chiplevel engineer to correct the mother board as there is problem with powersupply section in ur motherboard
Oct 22, 2007 | Dell (8N816) Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
