Question about JVC AV-27950 27" TV
I have a 29 inch JVC AV series.. but the picture soesnt not fit to the screen.. therefore some words at the corners may be incomplete. what can i do?
  • 1153 Answers
SOURCE: JVC AV 270305 Brightness not Bright enough.
Yes you could look for the capacitor that is leaky, probably in the 200v line, or you could just open back and turn up G2 screen control on the Flyback. You have Screen and Focus on this black transformer with a long anode lead going to the picture tube of set. Becareful, High Voltage!
Posted on Sep 08, 2007
wyoed1
  • 211 Answers
SOURCE: jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Posted on Jan 05, 2008
  • 275 Answers
SOURCE: jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Posted on Dec 01, 2008
  • 4234 Answers
SOURCE: Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Posted on Mar 21, 2009
  • 132 Answers
SOURCE: bright horizontal line across black tv screen
Hi There,
If your picture has collapsed to just a horizontal line across the center of the screen, this indicates that your Vertical Output circuit is bad and needs to be serviced by a qualified technician. I hope this helps and thank you for using FixYa!
Posted on Mar 29, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
What does 700 series 29"mean?
700 series is the type of video card, 29" is the size of the monitor measured from the bottom left corner to the top right corner in inches.
Mar 24, 2015 | Computers & Internet
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Mar 06, 2011 | JVC AV-27730 27" TV
Is a picture tube the same thing as a tv lamp
No! the lamp restores the back light on the screen so it is visible. The picture tube is a large bell that generates high voltage and with the aid of circuitry produces a picture.
Jan 10, 2011 | JVC AV-K29MX1U 29" TV
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
Bright horizontal line across black tv screen
Hi There,
Mar 29, 2009 | JVC Televison & Video
Sep 08, 2007 | JVC AV-27530 27" TV
Jvc model av36230
you know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
May 16, 2007 | JVC AV-36320 36" TV
Picture not fitting on screen
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
JVC AV-27950 27" TV Logo
48 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
