Question about Ariston Technologies Dishwashers
We have an ariston LS 620A dishwasher. For the last year every few months the dishwasher seems to cause a short in our electrical box causing all the power to go out in our house. It is only when the dishwasher is on that this occurs. We turn the power back on and everything, tv computer etc starts then turn the dishwasher on and everything shorts out again. We have had an electrician in who said that there was no electrical problem and that it was the dishwasher. After 2 months or so the dishwasher was turned on and no short occured. Then a few months later another short in the electrical supply when the dishwasher was on. We called a dishwasher repair service who couldn't find anything wrong either. He told us we were probably using to much powder. 2 months went by and the dishwasher started again. Now after another few months the dishwasher was toward the end of its cycle and the short happened again. We have been using tablets instead of powder so it is not excessive powder. The electrician says our electrical service is ok. We don't want to spend another $100 for someone to come to our home and tell us there is nothing wrong. Please help.... David Rose
  • 901 Answers
The problem seems to be water seepage into the electrical contact.
If the heater has lost its insulation this problem could accur
( element to body )
Disconnect the heater and give a try without any load and soap. If it
performs OK , you have to check the heater by removing from the
machine. Mainly I suspect water seepage into the electrical system.
Posted on Aug 30, 2010
I smell my motor. Is it worth replacing, or buy new?
5 years seems short for a major appliance designed to give 10 years or more of service. I'd say it's worth repairing yourself.
Just make sure it is the motor, then dig a little deeper to find out why it failed. It can be from being bound up because of a jam in the pump, a leak causing the bearings to freeze, or in the case of inductive motors a failed starting/run capacitor.
I've seen failure of the waste water gate/valve solenoid due to a timer issue. You'll have to do your detective work and once you know exactly the part that is eminating the smell, you will have a path to backtrack from.
Remember, water and electricity don't mix and shut both off before working inside the dish washer!
Jan 30, 2016 | Kenmore Dishwashers
I have a 2001 Nissan sentra and it keeps burning out altenators. Does anyone know what can be causing this?
need to load test with the car running, check for belt alignment also..seems to be quite a bit of power going somewhere..
Feb 07, 2013 | Cars & Trucks
Hoover HD73M dishwasher keeps tripping the circuit breaker
Have condensation in the electrical connector .It is grounding .Call an electrician to repair ground and short circuit.
May 10, 2012 | Hoover 24 in. HD73M Free-standing...
Dishwasher door leaks when in cycle. we purchased our dishwasher last year and have started to have problems for the last 5 months. Is there a recall
I have the same problem with model # lds4821ww. Seems the diaphram on the fan housing get dried out and causes it to leak down thru vent tube. Easy to repair just have to get part.
Aug 14, 2011 | LG LDS4821ST Stainless Steel 24 in....
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Something killing the battery
check for any lights staying at night, dome lights, sun visor lights for vanity mirror, glove box lights and so on, also have the battery tested, a bad cell can cause the battetry to run itself low, any Autozone or Kragen will test the battery for free.
Nov 04, 2009 | 2001 Lincoln LS
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
323 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
