Question about Hoover HTC243 Top Load Washer
Hoover 200m Top Loading Machine Spin Cycle Too short
My Hoover has a very short spin cycle.(I minute)
Is this normal?
Clothes still wet.
  • Tobor1 May 09, 2008
    The washing machine washes, fills and drains as per normal.
    then at the final spin cycle the pump just keeps running until the final click on the dial, then spins for about 1 minute then stops.
    It appears to sit there and drain even if there is no water in the tub.
    Hope that this helps
  • 150 Answers
No not normal many different things can be wrong need more info
Posted on May 08, 2008
  • andrew kinslow May 10, 2008
    gotcha. sounds like you have a problem with the timer. this may sound strange but you can confirm this by lifting the lid after the unit goes into the final spin cycle (when it just sits there draining). when you do this if the unit goes into spin upon shutting the lid you need a new timer. this unit has a neutral spin gearcase and it won't shift into spin until it gets a pause the reason for this is to allow the tub to drain alittle before the spin starts your timer isnt giving it the pause I think
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
How do I fix my spin cycle the clothes are still really wet it spins but the clothes are still wet
Hi Russell, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Washing Machines
Problem Hoover 200m 4.5kg top loading Machine not drain water
no drain? do u have a spin cycle working? If so check the water pump and hoses for clogged blockage. or broken obstructed propeller, can u turn it (pump) by hand?
Mar 02, 2015 | Hoover Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Clothes still wet after wool cycle
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Jan 31, 2010 | Washing Machines
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
Kenmore washer spin cycle doesn't leave clothes dry
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Hoover HTC243 Top Load Washer Logo
169 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
