My projector think that there is too high temperature and when I touch it its
  • 11,800 Answers
Open the projector and clean out all the dust in it with a fine brush.
Posted on Aug 30, 2010
Temperature and lamp error
Your projector will turn off automatically if the temp inside the projector gets too high. Make sure the filters are clean and fans are working properly. They run about 90 seconds after the projector is powered down.
Nov 04, 2013 | Mitsubishi ES200U DLP Projector
Fan fail error. projector shall shut down automatically
If the Fan fails the temperature goes up and so the temperature is detected to be high to cut off the projector.
Please replace fan or correct the power to the fan.
Apr 02, 2011 | Acer X1230 DLP Projector
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
The projector comes up then runs for awhile then shuts down. I checked the fan and that seems to be ok. I also checked the capacitors and those are good as well. I have summarized the the ballast component...
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector ro provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 20, 2010 | BenQ MP720p Multimedia Projector
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
After five minutes of working properly, the Cine1000 projector goes dark and the ready lite goes out. The power lite stays lit. The lamp has 881 hours. I checked the menu and auto power selection is off....
get a small fan and place it near the projector to provide
The lamp reset...should only be used when you replace
the lamp..with a new one...The reset will start the clock
running on the number of hours the new bulb has used..
Jul 18, 2010 | ViewSonic Cine1000 Multimedia Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Lamp bulb indicator is red and unit will not light up
Also, check and clean the air filters.
Jul 17, 2010 | Optoma HD65 DLP Projector
Projector heating up and bulb shuts down
Jul 08, 2010 | Dell 2300MP Multimedia Projector
After having the projector on for 15-20 minutes the lamp will go out for 1-2 minutes then turn back on with no intervention This will repeat at no set intervals. The projector is not quite 5 years old...
Jun 28, 2010 | InFocus ScreenPlay 7205 Multimedia...
Open Questions:
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
