Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I NEED A DRIVER FOR MY SANDISK USB, COZ I TRY ALL I SHOULD TO RECOGNIZED IT BUT AFTER ALL THE DISABLE, UNISTALL, RESTART, SHUTDOWN... STILL USN UNRECOGNIZED... WHAT SHOULD I DO?
  • 2,335 Answers
Everything your Sandisk Cruzer USB driver needs to run should be on the usb drive itself, unless you have erased it, in which case you may have a problem.
The correct way to use a Sandisk Cruzer is to plug it in so that it lights up and then not touch anything on your computer until the orange sandisk symbol appears on your desktop. Right click this app and use it to browse your USB drive and eject it when you are done.
I hope that helps.
Posted on Aug 30, 2010
Downloaded drivers for a new Samsung M2830DW and will not print. Computer does not recognize printer. Help???
Dear
Some times the front usb port arnot work. try to connect the /replace the usb cable to the usb port mounted on motherboard(back side panel of pc), It also may happen the usb port may disabled due to virus. Also you can unistall the driver during power OFF of the printer after uninstall successful power ON the printer, it will show NEW HARDWARE FOUND at the right right bottom of the pc screen ,If you OS is win 7 and connected to internet the driver automatically installed, otherwise you can load the driver cd and install the driver.
Also it can be checked at control panel-add hardware.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
Usb device not recognized when I plug phone into laptop, it always worked before
in device management uninstall all USB drivers. restart the laptop.
if it still dont work then unistall the software for the mobile. restart the laptop
install the software again, then connect the mobile.
if still not working try your mobile on another pc or laptop, if it work then you may have a problem
with your windows USB drivers, which mean you will need to reinstall windows on your lap.
you can test you mobile with another usb cable also on your lap.
good luck
May 28, 2011 | HTC Hero Smartphone
Hi, I have a Sandisk Cruze Blade 4 GB USB Drive, but Windows 7 64 bit OS does not recognize it. I have searched internet for 64 bit driver, but I didn't find it... I need a 64 bit SANDISK Cruze Blade...
Do you have a legit copy of windows, sometimes if the copy is (Backup) then Windows will purposely disable drivers.
If, its a genuine version, first try plugging your usb device into another usb port somewhere. Try powering down your PC and powering it back on. If these steps do not work, go to Start>Contro>Driver/Devices and look if there is any Yellow caution signs with the device plugged in. If so, click on it and follow the steps prompted to find the appropriate driver for your USB device. It will do a search by itself.
Hope this helps-
J.Sper
Mar 06, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
The SanDIsk USB drive seems to be "malfunctioning". The computer will not recognize it and therefore no recovery software can find it. I need to recover the date from it and do not want to...
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
if this does not fix the problem you might try
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
don
Feb 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sandisk worked on my laptop but will not work on my computer. The computer doesn't even recognize the drive.
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect sandisk to computer then cehck if still face problem try all usb port of computer.
Aslo check your usb port of computer are working fine.
Jul 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When installing printer and I get to the section that tells me to plug in USB it does not recognize my printer. We are running windows XP
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
PREM
Apr 07, 2009 | HP Photosmart C4480 All-In-One InkJet...
Computer does not recognize the usb device
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
SanDisk not recognized by computer
Follow these steps:
  1. Go to START > Right-click My Computer > PROPERTIES
  2. On the tabs, click Hardware > DEVICE MANAGER
  3. Press the + sign next to the Universal Serial Bus controllers.
  4. Doubble-click the first one
  5. When the new window comes up, click Drvers from the tabs, and click "uninstall"
  6. Repeat step 5 for all devices
  7. Restart your computer.
After your computer restarts, plug in your flash drive and it should work.
If that doesn't work, then the USB ports on your computer are dead. You can try to get new USB hardware at a computer store to plug into your computer (THIS IS NOT THE SAME AS A USB HUB!)
Feb 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dell photo printer 720
NO u just need first to UNISTALL driver then restart pc and install again from device menager not from setup
Oct 12, 2007 | Dell Inkjet 720 Printer
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
174 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
