Acer Aspire 5000 Laptop
I am trying to use a Envision screen in place of my laptop screen. I have the plugs in the proper place. When I boot up my laptop the Envision screen boots up and once it shows my windows xp signal, it shuts off and indicates no signal.
  • Anonymous May 09, 2008
    It's the Fn 5 key that I am using and once I click on that it brings up 3 boxes. (laptop,laptop to screen,display) I can't seem to keep it on the middle one. I know the envision screen works as I had a Dell Laptop hooked up to it. The envision screen starts up and shows a windows xp logo than it goes blank and indicated no signal
    Brigadier General:
  • 6,966 Answers
Normally, you would need to press Fn + F? to activate/enable the external display of the laptop. The F? depends on the make & model of the laptop. It would be one with the monitor icon on it.
In some instances, it may be necessary to lower down the Screen Resolution and the Screen Refresh Rate in your laptop's Display Properties.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
Looking for a manual for this comp want to plug a microphone in but one i bought doesn't show up on screenwant to make sure have pluged in to the proper place
Please use this download:
Acer Aspire 3000 3500 5000 service manual
Acer Spire 3000 5000 user guide
There's only one place you connect the microphone, and that would be the "red" jack on the front of the unit. The unit however should have a internal microphone as far as i can recall...
May 28, 2010 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
My friend acer aspire one cant open and becomes blacked screen...
Take out the battery,unplug the power cord,and hold down the power button for 30-45 seconds,Then put the battery back in,plug the power cord back in and start the computer.
Jul 30, 2009 | Acer Computer AOA150 Notebook
No desktop Icons
Troubleshooting first:
  1. does it start? Yes: go to its BIOS and set your CD drive to be the first one to boot. Read the screen menu on what to press to enter BIOS or read manual. No: Check your power supply if it is properly plugged and the battery for it might be loose.
  2. does it display your windows start button? Yes: right click on the display and select arrange icons by: then select "show desktop icons". No: your computer might not have proper boot up. need to restore and follow the above solution.
Mar 31, 2009 | Acer Aspire 5000 Notebook
Acer Aspire 5000 laptop with SiS 760_M760 video driver
The Aspire 5000 actually has a 128mb video card. i am using one right now as a matter of fact. Reboot your acer. when you see the acer logo. press F2 once into the bios screen move to the next tab. High light the 64mb next to the video adaptor and high light 128mb.
Feb 06, 2009 | Acer Aspire 5000 Notebook
My Acer Aspire 5000 won't turn on. I hit the power button, the light turns on for half a second then blinks off again. The HD doesnt start, neither does the fan and the screen never coms on. The battery is...
sounds as if the laptops in hibernation or sleep mode.
Try refering to the user manual regarding the mentioned points.
also try alternating the memory from slot to slot, 1 faulty slot or ram module, will cause the computer not to boot.
Finally, if this is a model that has a ribbon-cable from power switch, to motherboard. ensure it,s inserted correctly/square et,c.
Hope this helps, thankyou for using Fixya.
mike @ Compurepair.
Nov 26, 2008 | Acer Aspire 5000 Notebook
Have you tried changing the power settings,in control panel go to power options and change the time settings for when the laptop is plugged in and running on batteries.
Also change the power scheme to Portable/Laptop.
I hope this helps,please let me know WF
Aug 20, 2008 | Acer Aspire 3000 Notebook
Acer 5000 screen problem
Hi again,
Have you tried lowering down the Screen Resolution and the Screen Refresh Rate in your Acer Aspire 5000's Display Properties?
If you are not able to do that, pls post back that I may walk you through the procedures.
Cheers.
May 13, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
390 people viewed this question
David Payne
David Payne
