Question about Singer Sewing Machines
Machine worls OK with ordinary materials; but with heavier or soft materials it starts to stitch and then there is no stitch. Machine has been oiled and cleaned and I have tried changing the tension. Model 290C
    Genius:
  • 1,788 Answers
Use the right needle size, the lower the number is for soft material, such as #9 or heavy material use #16 or #18. Download a free manual at singerco.com under support
Posted on Aug 31, 2010
The stitch length is messed up on my Pfaff 7570. If I change it to about 4.5 then I get about a regular stitch length (2.5). I can't baste, the max stitch length is not long enough.
Perhaps this DIY web site would be helpful. I'm wondering if the feed dogs may did a teensy bit of oil to help them move. (Perhaps use a good quality oil or liquid Tri-Flow Synthetic Lube.)
Pfixing the Pfaff
BTW, did you happen to see this:
http://www.fixya.com/support/t26660891-stitch_balance
Jul 13, 2017 | PfaFF Sewing Machines
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
Sewing through thick material not working for me. Doesn't catch all the thread and leaving gaps of no stitches on the top and bottom. What can be done?
Hmm, interesting combination of problems.
Try a brand new needle (push it all the way up into the needle apparatus while tightening) and check that it is the correct needle for your machine (sometimes machines will have more trouble using Singer or generic brand needles). Also, is the needle inserted facing the proper direction? Verify that you are using the correct needle type for the fabric you are sewing, ie sharp for woven fabric, ball point for knit.
When stitching, do not pull or push the fabric through your machine. Sometimes that will cause skipped stitches. If you are having trouble getting the fabric to feed through the machine, you might try a teflon, roller, or walking foot that will help pull the thicker fabric. Check that the presser foot pressure is adjusted for heavier fabric.
All About Needles
Basic Maintenance Tension Skipped Stitches
http://makeitsew.biz/presser-foot-pressure
P.S.--as an after-thought--are you using a heavier needle like a #14 or higher? If not, it could be that the lighter weight needles are deflecting when penetrating the fabric causing missed stitches.
Feb 12, 2017 | Sewing Machines
The fabric I am sewing is very soft and therefore the stitch does not hold onto the material, works fine with cotton etc. What do I need to do to so the stitch is showing. Manual didn't help. Thanks
Hmm, right off the needle comes to mind. Have you tried a new needle? Sometimes a needle dulled on woven fabric will not work well on knits. If you are stitching a knit fabric, you may want to use a ballpoint or stretch stitch needle.
Jan 23, 2016 | Sewing Machines
Sewing machine not working in reverse
try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Jan 11, 2013 | Sewing Machines
CE-5000 thumping sound when I sew, messy stitching
any sound out of the ordinary could mean that a part is worn or fixing to break or something is loose
it's very possible that the machine needs to be serviced
Feb 08, 2012 | Brother CE5000 Computerized Sewing Machine
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
I have a Euro Pro Shark Automatic. It works perfectly as a rule. I am trying to sew heavier material than usual - new inserts for my exterior sling chairs. The thread is heavier nylon and it catches on...
Most domestic sewing machines will not handle heavier thread than the standard 50 weight. I'd suggest you go back to regular polyester sewing thread and use a 110 or 120 size needle to cope with the heavier fabric. Sew slowly and give it some help on the flywheel when crossing a seam allowance. Maybe stitch each seam twice, with a 1mm gap between to give it strength.
If you need to use the heavier thread to do the job then you will probably need an industrial sewing machine that can handle that grade of fabric and thread. Something like a Singer 20U machine in a table with seperate motor drive.
Fabrics like Canvas, ticking and PVC for exterior items are generally going to be beyond the functionality of a domestic machine and you can damage the machine, particularly the timing by trying.
Aug 23, 2011 | Euro-Pro Shark 80 - 7133
Uneven stitches while machine quilting.
Are you using the right size needle and thread? Also, check tension recommended by your manual. Let me know if that helps, because I can ask my sister who has that machine
Jul 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
