Question about Poulan Weed Eater Rte115 4.5 Amp Electric Trimmer
Replacement spark plug for Talon AT3351 whipper snipper? Can anyone help with New part number?
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
Where can I buy a pull start Spring for a Talon At3351
Hardware Store, or local mower repair shop.
Oct 13, 2014 | Garden
Restringing a talon hawk whipper snipper
There may be a latch that has to be released in order to rotate it.
Jul 19, 2014 | whipper snipper Garden
Pope whipper snipper starter cord problem
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Feb 09, 2014 | Garden
What would have caused my talon whipper snipper to seize?
hello, lack of lubrication will make engine seize up,and also when the trimmer is hung up with the engine down the cylinder will fill up with fuel to where you cant pull rope,found this out myself,hope this helps,,
Feb 20, 2012 | Garden
What is the spark plug gap on a Talon 25cc blower vac (AB320325)
The same engine on a Talon 25cc whipper-snipper has a plug gap of .025" according to the owner's manual.
Dec 11, 2010 | Garden
Talon Whipper Snipper won't start suspect fuel not getting through
I have the same problem. The plastic primer has broken into pieces. i have emailed the Talon help desk - 'customer.service@husqvarna.com.au' but no reply as yet
Dec 13, 2009 | Talon Electronics - Others
Looking for a manual.
You can download the manual from;
http://www.stihlusa.com/stihl_ownersmanuals/FS_45_46_Manual.pdf
and yes since it's second hand replace the spark plug.
Apr 23, 2009 | Garden
Poulan Weed Eater Rte115 4.5 Amp Electric Trimmer Logo
161 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
