Question about Cameras
THE LENS WILL NOT OPEN - Cameras
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 30, 2010
Lens cover wont open
Common problem with automatic lens covers. I use a toothpick to manually open the lens with the camera on. The use some glue, small amount on the lens cover to glue it open. Then I would carry it in a carry bag.
Nov 24, 2013 | Cannon Cameras
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Lens cover will not open
easy fix. yo turn it on and then very lightly tap the lens cover or push it out. then you should clean the lens because the dirt or dust on the lens is stopping the lens cover.
Aug 24, 2009 | Canon PowerShot A530 Digital Camera
Canon A95 stopped working with lens open
ur lens belt is broken relace it or write to me
Jun 17, 2009 | Canon PowerShot A95 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens Cover Won't Open
NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Lens
1. What lens wont open?
2. Please give details about your camera type and the short history of what happened for the lens not to open
Jan 07, 2008 | Sony Cybershot S650 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak DX6340 Lens Cover Does Not Open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Aug 13, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
