Lexmart 4200 program want delete. program running comes up wait till program complete. no printer conected.
Lol
Posted on May 10, 2008
Document failed to print
There are some printer order pending in your computer. For these reason you may to remove printer order. To cancel print order follow these proces
Start - printer and fax> printer icon double click> show window> then delete print order.
Now unpluge all the conection both usb and power. Wait few minites, and then reconect conection again
Thank you.a
Now , op,
May 19, 2011 | Office Equipment & Supplies
I do not know how to use the scanner on my printer SCX-4200
Twain
Hi, normally, if you have installed the complete driver set, the easiest way is to run a program with scanning capability i.e. photoshop, or word. the software normally given with a scanner is a 'twain' which becomes linked to the picture receiving program. If you have MS word (I'll use this as an example ), ensure the scanner software is installed, the scanner switched on and connected to the computer correctly click Insert select picture then scanner - (or it may say twain). At this point the scanner mini program - the 'twain' should start and then follow the scanner instructions and a scan of whatever you have selected should be inserted into the word document. Bit of trivia - TWAIN stands for Tool With An Interesting Name - yup it really is!.
Mar 05, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Lexmark X8350 can't delete from Print spool
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X4270 All-in-One Multifunction...
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Hp 1210 printer
Disconnect USB cable & turn Printer OFF.
Then Clear all pending documents in the printer queqe.
Control panel printer & faxes>> Printers.
Double click printer icon & start deleting all document fron this queqe.
Then restart pc. After restart delete the printer icon completely.
Later connect usb cable & turn on printer wait for few minutes till printer configures & start printing.
Jul 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
I cannot load the software drivers to my Lexmart X6570 printer. It will make a straight copy but will not print from the computer or scan. I have tried the CD that came with the printer and tried to...
hi is the pc your on xp or vista ?
some printers are not compatible on vista if this is what your using there is however a fix for this go on the net and down load a program called driver genius 2007 pro this will find any driver problems on your pc sys and down load the drivers to fix any problems on you pc complet .
hope this helps ok thanks
May 22, 2008 | Lexmark Office Equipment & Supplies
Error During Scanning
Please check whether any other scanner is installed or not .It might be creating the conflict.
Pls remove it.
Haoppy scaanning
Omnipresent
Oct 23, 2007 | Samsung SCX 4200 All-In-One Laser Printer
jasbo
jasbo
