When i connect my Compaq Presario with my Samsung LCD TV , the display appears but an Error message saying"Check Signal Cable" remains on Screen .. Quite Annoying that is...How I can I get rid of this message...????
    President:
  • 2,291 Answers
Put out ur battery and insert it again and then check
Posted on Aug 30, 2010
COMPUTER IS FROZEN..ERROR MESSAGE SAYS CHECK SIGNAL
So the message you get on your screen is telling you that there is no signal coming from the computer, Screen and computer are different parts, the screen is not your computer.
So this means that your computer is either not connected to your screen or not turned on. if it is turned on and properly connected, you have a hardware problem, take or have someone come over to inspect the pc in person.
Feb 03, 2013 | Compaq Presario 7478 PC Desktop
COMPUTER IS FROZEN,,ERROR MESSAGE SAYS CHECK SIGNAL
Try another communication cable if doesn't work you may have problem with you video card.
When I connect my Compaq presario V6000 to my Samsung 32inch TV (to use the TV as the monitor) using the VGA ports on the computer and the TV and switch to PC source on the TV the Windows boot screen...
1. Go to Control Panel-->Hardware and Sound.
2. Click Connect to external display in Display section.
3. Click button Detect.
4. Your TV should be detected, now you can also set resolution and choose whether you want to use just TV as your monitor, or both TV and laptop screen.
Sep 05, 2011 | Compaq Presario Notebook
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
Connecting Sony Vaio to Samsung TV
The problem is the cable. Those converter cables rarely work. they can't translate the scan rates properly. You need a converter box for the video signal, and get a cable to plug into the headphone jack on the laptop to send sound to the audio input on the TV. Here's a link to an example of the type of box you need to get the video working.
Hope this helps!
Joe
Apr 07, 2017 | Acer Aspire 5102WLMi Notebook
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
