Question about Epson ACULASER CX11NF All-In-One Printer
ADF not feeding paper - Epson ACULASER CX11NF All-In-One Printer
  • Epson Master
  • 1,879 Answers
Try this, check the white plastic flap under the ADF, it should go under the cylinder.
Posted on Aug 30, 2010
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Long black line from near top to bottom only when using ADF, not flatbed.
Your ADF is not feeding the paper straight. The black line is the gap created when the edge of the gap
has a gap along the edge.
* Adjust your feed bars so that it holds the paper tightly centered to the ADF.
* Check that there is not dust in the feed path of the ADF roller and it is clean.
Mar 22, 2011 | Office Equipment & Supplies
Paper feed only works manual
I think you have a paper jam or some other tiny objects like a paper clip or the like blocking the ADF(Automatic Document Feeder) roller. You should open your ADF and check for anything obstructing the roller. If you see something just pull it off close the ADF and turn on the printer.
Good luck,
Sai.
Dec 02, 2009 | Brother HL-2070N Laser Printer
We can receive but won't take the paper to send a fax out
You have an ADF paper feed problem, try taking some rubbing alchoial and clean the ADF paper feed tires, This helps the paper to feed into the scanner unit so the fax can be sent. I have also seen part of the ADF feed unit broken.
Does the paper feed in but not transmitt out?
Aug 28, 2008 | Sharp Office Equipment & Supplies
Adf doesn't feed
Did you check the sensor in the ADF? there has to be a lever that moves when inserting a paper in ADF to let it know paper is present. is it stuck? it should have a spring action, so it returns to its positiion when paper is no longer there.
Aug 28, 2008 | Office Equipment & Supplies
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
ADF Paper Feed on Ricoh Aficio 1013
1-clean rubber belts with lint free clothes immersed in pure alkohl
2-remove adf covers and confirm that nothing broken inside(gears-belts)3-every clutch and selonid are in good condition.
4-solonid lever engaged firmly to gear slevee 5-apply light grease to gears and slevee6-confirm that nothing object the actuation of adf microswitches no dust and dirt in optical switches.
Mar 05, 2008 | Office Equipment & Supplies
Epson ACULASER CX11NF All-In-One Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
