Question about DeLonghi DEFSGG36-SS Gas Kitchen Range
Our DeLonghi stove worked well, then suddenly all of the gas igniters stopped working. Stove lamps, timers, etc and everything else is OK. Any help as to where to start checking? Alex
  • DeLonghi Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 31, 2010
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool SF330PEWW5 Completely Dead
Open the backguard on the range to access the electronic control. If you read 120 volts into the control and nothing works,...replace the control.
May 24, 2009 | Whirlpool SF378LEP Gas Kitchen Range
GE gas stove top igniters won t stop clicking
I got this problem yesterday. My 6-month old GE range/stove top was being cleaned by a cleaning lady and suddenly, the igniters started clicking nonstop. I had to shut down the circuit breakers. I googled the problem, and it seemed clear that the "spark switches" got moisture on them. The best site which described this is: http://www.appliance411.com/archive/25012_ge_gas_cooktop_not_working_.shtml
Some people said you could dry them with a blow dryer, and others said you need to replace these switches (which is not too expensive, but takes some time/skill). I was hoping against this, so I tried something along those lines: I removed all the parts of the stovetop - the grill, the "cap", the metal funky piece, etc. until there was nothing but the surface of the stove and holes going down to the igniter area. Then, I took an electric fan and kept it pointed at the stovetop all night long. After about 10 hours, I turned the circuit breaker back on. No more clicking! And the burners all work! So, I think I essentially did the "hair dryer" solution, but did it more longterm without having to watch the clock to see if I did it long enough. Anyway, I don't normally post these things, but this discovery really helped me and I hope it helps someone else!
Feb 12, 2009 | Kitchen Ranges
Gas stove top not lighting - gas is on/electic to appliance is ok
Is it a (relatively) new stove - i.e. piezoelectric spark igniters?
If so, is there a "lite" or "pilot" (or some such) position on the knob? On most stoves you have to turn the knob to that position, it starts clicking, you may smell a little gas, and then it lights.
Is that happening?
When you turn it to the lite position, can you see a little spark in burner. Often these igniters stop working and need to be replaced.
Let me know.
Mar 13, 2008 | Kitchen Ranges
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
DeLonghi DEFSGG36-SS Gas Kitchen Range Logo
418 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
