Hi experts, I have a Hotpoint WMA62. In the past it suffered from the bearing problem, and today it has stopped completing the wash cycle - barely starts it infact. I don't have a warranty and wonder if I should replace or repair it. I think it's about 5 years old. many thanks, Sandi
  • sandil May 09, 2008
    Dear gittos73, I checked the machine last night and it is exactly as you described it. Thanks!
    Novelist:
    Champion:
  • 244 Answers
Is this that the drum doesnt go round much or at all when turned on but lets the water in if it is then its just your carbon brushes and will only cost no more then £15 to buy them let me know
Posted on May 08, 2008
  • peter gittos
    peter gittos May 09, 2008
    your ok m8 just dont let anyone rip u off
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
My waashing machine a WMA62 Hotpoint comes on, you
that sounds like your heating element is o/c .... get your heater tested ..01179512835
Dec 30, 2009 | Hotpoint Washing Machines
Hotpoint WMA62 shaft removal
draw off the spider with a pulley extractor,
Sep 03, 2009 | Hotpoint WMA64 Front Load Washer
Hotpiont wma62 not washing
check the motor brushes and connections to the motor the fault is logged as motor action fault.
Jul 12, 2009 | Hotpoint WMA64 Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
WMA62 Won't Progress Through Programme
check your brushes in the motor if they start to fail then it would act like this failing that then it will probably be the programer.
Aug 09, 2008 | Hotpoint WMA64 Front Load Washer
Washer stopped dead in the middle of cycle
CHECK ALSO the sensor switch underneath where the door close , you gonna need a tester for this task ,hope this helps AJ
May 05, 2008 | Hotpoint WMA13 Front Load Washer
WMA62 aborts all programs after 2 initial spins
if this washer is trying to spin when you put it on a wash cycle at the beginning and it trys a fast spin then you have a timer fault m8 if on the other hand its working fine through the wash cycle and not doing the spin properly then it has to be your belt isnt tight enough if your cab=rbon brushs are fine m8
Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
