Question about Car Audio & Video
When i go over 50 the car starts to vibrate when i come off the power the vibration stops
  • dieseldave51 Aug 30, 2010
    thanks i will try wheel balancinge first
  • 11,800 Answers
Some rotating part is not balanced properly and when its vibrations match the body of the car it goes in resonance and increase dramatically.
You need to find that part and balance it. Start by balancing the wheels. If this doesn't fix it then take the car to a shop, lift it out of the ground, find out what shafts have a lot of play and replace their supports. Ideally you should start the car while the wheels are off the ground and rev it while looking at the shafts, you will see the one that is vibrating.  To balance a shaft you need a specialized shop, if you can't find one in your area then just replace it.
Posted on Aug 30, 2010
Had the engine replaced did not vibrate, now between 40 and 50 mph has vibration when you let off the gas it stops, any suggestions?
See if the driveshaft or flywheel might be loose. I would try to narrow down were the vibration is coming from.
Jun 05, 2015 | 2005 Dodge Durango
Driving between 35-50 mile ph truck will start vibrating
There are many stages of vibration. The most common is in the steering and USUALLY a steering dampner will correct this. However, your description is not real defined and until the technician actually experiences it, it cannot be properly diagnosed
Aug 24, 2017 | Chevrolet Blazer Cars & Trucks
Pathfinder vibration
check the "u" joints for looseness and wear especially the front drive shaft . check sliding splines . The vibration is a harmonic vibration normally associated with worn "U" joints --bent or out of balanced ---worn /seizing slip joints or being excited by a failing drive thrust bearing in the diff. ( big bearing directly behind the pinion gear that takes all the load on drive) check the magnet on the diff drain plug for metal bits.
Jan 28, 2014 | Cars & Trucks
From a stand still if you accelerate hard vehicle starts vibra
Well, kind of short on description, issues typical in this complaint are misfiring and U joints.
To emininate the engine, does the vibration happen on power braking, without the vehicle moving?
May 24, 2010 | 2000 Chevrolet Blazer
Have grand caravan 2001 awd i get to 50 it starts vibrates think it might be carrier bearing after 50 it seems to lessen some no problem in front end what do u think
Most vibrations at speeds from 45mph to 55mph indicate tire balance problems. If there is no vibration outside this range have the tire balance checked. If there is a vibration that starts around 50mph and continues at higher speeds there could be a problem with the CV joint(s).
Nov 05, 2009 | 2001 Dodge Caravan
My 2003 rav 4 vibrates on rear end while driving ,i hav a 2litre turbo diesel as i move up the gears it vibrates all through the car when u get to a steady speed it stops vibrateing ,even when u let the...
I would suggest having your universal joints checked out , sounds like a bad joint or bearing somewhere in the rear end, if you can get your speed up to about 50, put your rav in neutral and let it coast if it stops vibrating, it most likely is your problem
Mar 24, 2009 | 2003 Toyota RAV4
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
