Question about Simplex Kaba Ilco Unican 1000 keyless lock
I'm a firefighter and we had an issue trying to get to a patient behind on of these locked doors later on. The ambulance crew said there was a master code but they didn't know what it was. I was wondering if you knew what is was. We have several of these types of locks in our district.
    Problem Solver:
  • 19 Answers
There is no master code. To have such a thing would make every one of these locks useless if it got out. Generally this type of lock can only have 1 code at a time.
Sometimes a company or housing community that uses these locks will use the same code for all of them, and they may call it a master code but it is something that they have set on their units only.
The best thing you can do is to contact places which have locks which could prevent you from accessing a patient and see if they will give you the code. Unfortunately, the problem with this is that codes get changed and the fire department is not notified.
Then again, the fire department goes on medical calls for just this type of thing. Grab the irons off the truck and force the door.
Good luck and stay safe.
-FF/EMT
Posted on Sep 07, 2010
What is the working principle of air ambulance?
Actually, when an air ambulance takes off they keep everything of patient needs in flight. Air ambulance services is very conscious of their work they will provide you common equipment in ambulance includes medications, ventilators, ECGs and monitoring units, CPR equipment, and stretchers. In that ambulance, you will get experienced nurse and staff for medical care but in normal flight, you will not get any types of care.
Feb 09, 2018 | Cars & Trucks
What are the benefits of an air ambulanc?
If you will choose air ambulance then you will get many benefits include:
1. The first advantage of air ambulance service is it can save someone life Becouse it is very fast and safe then the ground ambulances.
2. In air ambulance, you will get all the medical provisions when the patient needs any instant medical care they can provide them immediately.
3. Air ambulance is much comfort and convenience than a ground ambulance. Because by road patient will feel more tired and this tiredness is not good for the patient.
Feb 09, 2018 | The Computers & Internet
Who needs an air ambulance?
Whenever the patient is in a serious position and they have to travel more than 250 miles and they need some immediate treatmen That time only patient need air ambulance.
Like the patient is suffering from cancer, burn, head and spinal cord injury and strokes. For this type of serious issue, they need it. So if you ever need you can try this air ambulance it is very safe and reliable here you will get experienced or trained staff for your care.
Feb 08, 2018 | CARE Health & Beauty
1992 Ford Econoline Type 3 Ambulance. We have heat in the cab, but no heat in the back box where the patient is treated. Any thoughts as to why this might be?
what is your model number is then we can get started
the model is on the drivers side door on the edge of the door
Jan 14, 2013 | 1992 Ford Econoline
My fisher & paykel washer wont start it beeps and says the lid isnt closed, but it is and there is a little ambulance that comes on the screen
I believe the lid switch is faulty, for the later modules the microswitch is mounted inside the door lock mechanism, others under the lid/top left side.
The ambulance is just saying to call for help....
May 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
Door adjustment for a 96 f350 dropped about 1/2"
Here's the solution: You might want to park it under a tree and tie a rope to the door to pull it up when loosened.
ADJUSTMENT Fig. 1: Door hinge adjustment 84920001.gif
Fig. 2: Rear door hinge adjustment, F-350 Crew Cab 84920002.gif
NOTE: Loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
  1. Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  2. To move the door safely, use a padded prybar. When the door is in the proper position, tighten the bolts to 19–25 ft. lbs. (25.5–34.5 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  3. Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
Jul 13, 2010 | 1997 Ford F350 Crew Cab
My door ajar light stays on constantly. therefore my doors don't automatically lock when put into drive and constantly dings when the keys are left in ignition. what's up withthat?
take and spray wd40 on the latches and open close the door a few times and that should fix the problem that is what was wrong with mine. That took care of problem if that doesnt fix it the senors need to be replaced in the latch
Mar 13, 2009 | 2003 Ford F250 Super Duty Crew Cab
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
120 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
