The TV remote is not working and when i do it manually the following problems i face when i put on the TV, it opens with VIDEO ONE, one more press then it goes to DVD One more press then the channel appears The manual buttons does not functions on the TV The menu, volume & channels are not functioning Iam afraid if i repeat the same whenever i watch TV i might lose the manual functions also
  • 11,800 Answers
Try to use another remote - if it's the same then the problem is with the control processor of the tv - you are going to have it replaced at great cost.
Posted on Aug 30, 2010
How do I open the remote to replace the batteries on my Fire Stick.
To remove the back cover of the remote and insert the included AAA batteries:
  1. Rotate the remote so the top edge is facing downwards.
  2. Apply pressure on the indent of the battery door and slide upwards. ...
  3. Pull away the battery door and insert the batteries.
  4. Slide the door back into place and push in to secure.
Amazon.com Help: Remote Basics
https://www.amazon.com/gp/help/customer/display.html?nodeId=201452700 Feedback
About this result
Amazon Fire TV Stick: How To Open The Remote's Battery Door ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: Read our review of the Stick ...
Amazon Fire TV Stick Remote: How to Change Batteries - YouTube
? 0:54
https://www.youtube.com/watch?v=sBbTLXvWjzg
Jan 25, 2017 - Uploaded by WorldofTech
I thought I'd make a quick video on how to change the battery on your Fire Stick remote since my father said ...
Open Amazon Fire TV 2015 remote battery compartment - YouTube
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M Oct 6, 2015 - Uploaded by sfsilicon
then once it's open you push it down. it's still a little tough okay to about this this length okay. and then once ...
Installing batteries into Amazon Fire TV Stick with Alexa voice remote ...
? 0:40
https://www.youtube.com/watch?v=cZ1tidv478M
Mar 9, 2017 - Uploaded by Richard Robinson
You would think this part of getting your new device would be easy, right? Here's my easy to follow video ...
Amazon Fire TV Stick Remote Battery Replacement - iFixit
https://www.ifixit.com/Guide/Amazon+Fire+TV+Stick...Battery+Replacement/65199 If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick. Step 1 Remote Battery. Use the plastic opening tool to press into the seam between the remote and battery cover. Place two fresh batteries back inside the remote and slide the cover back on
replace the batteries on my Fire Stick Google Search
Jul 31, 2017 | Televison & Video
I bought the Sentry RMC10 Big Universal remote, but I lost the manual. I am not able search code for a Sanyo plat panel tv, Model DP26640-26" Diagonal LCDHDTV
The codes for Sanyo TVs are as follows.
  • 004
  • 013
  • 049
  • 108
  • 110
  • 180
  • 209
If none of them work, you can try the manual code search feature.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Nov 28, 2013 | Sanyo Televison & Video
I cannot get the remote to work. I 've replaced the batteries and followed the manual. It doesn't work.
Try the controls on the tv to make sure the tv is working.
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the tv.
Feb 18, 2011 | Emerson Televison & Video
How to open service code
Put TV in standby and press following buttons on TV remote.. Display, 5, Vol+ and power, service manual will open.
Jun 11, 2009 | Sony KP-48PS1 TV
Open service code
I just replied you.. Put TV in standby and press following buttons on TV remote.. Display, 5, Vol+ and power, service manual will open.
No video on tv monitor
To permanently fix the problem you have to send the unit to a programmer. A quick fix would be is to physically do it in your TV. While your Direct TV satellite receiver is ON, press the "TV/Video" or "Source" or "Input" button in your TV until the video will appear in the TV screen. All the TV has either one of this button.
May 18, 2008 | Universal Remote Control MX-3000 LCD...
AIWA TV-A2119 PROBLEM: SOUND MENU NOT COMING
THE PROBLEM IS YOUR TV MODE HAS BEEN RECONFIGURED TO KE1 MODEL. SO YOU WILL NOT GET THE AUDIO MENU. THE SOLUTION IS, JUST BUY AN ANOTHER REMOTE RC-ZVT03 MODEL AND USE IT AS A TEST JIG REMOTE. OPEN THE COVER, YOU WILL SEE THE CONTROLLER IC BW7461-3T ( 16 PIN). ACTUALLY TO ENTER IN TO THE SERVICE MODE, WE HAVE TO PRESS THE "TEST" KEY. BUT THAT KEY IS NOT AVAILABLE IN THE REMOTE. SO SIMULATE THE 'TEST' KEY, JUST SHORT THE PIN NO 4 AND PIN NO 12 THROUGH A WIRE TO ENTER IN TO THE "SERVICE MODE". ONCE YOU PRESSED THE PIN 4&12, THE TV WILL ENTER IN TO THE "AGEING MODE". THEN PRESS "AV MODE" SWITCH IN THE ANOTHER REMOTE ( YOUR CASE ZVT13). A MENU WILL APPEAR TO SELECT THE MODE. PRESS NUMERIC KEY "3" (INDA-1) TO SELECT THE "AIWA TV-A2119KE" MODEL AND AGAIN PRESS "AV MODE" TO EXIT. AGAIN PRESS THE TEST KEY TO EXIT. RESTART YOUR TV. NOW YOUR PROBLEM SOVED. SINCE I ALSO FACED THE SAME PROBLEM, I GOT THIS SOLUTION (jp_ati).
Enjoy.
Dr. M. Jayaprakasan, Chennai
Mar 22, 2008 | Aiwa F2000 20" TV
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
Old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Nov 03, 2007 | Televison & Video
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
