Question about Westinghouse W33001 30 in. HD-Ready LCD Television
My tv has no color its a faded gray picture. At first it was shutting off and not powering up.
  • Westinghouse Master
  • 17,129 Answers
Try to see if there is a change after soldering on the processor boards, the invertor /convergence IC 's.
If there is by any chance that one of the pins are not getting correct connection, the missing of a colour can happen.
So use a good soldering iron to solder without any bridging on the circuit.
Posted on Aug 30, 2010
Tv has sound and picture but color suddenly faded to a light purple. There were 2 loud bangs and the color was gone. We shut it off.
power board and control board are bad,consider a new tv or replace the boards,consider using homeowners insurance
Jun 29, 2015 | Televison & Video
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Tv makes buzzing noise then picture fades and eventualy shuts off
Ur colors wheel is dead,must call tech.for this is very difficult to take out,and replaced have no tv tech. experience.Best to call tv shop service,to replaced this colors wheel,and have warrenty on it.
Jan 11, 2010 | Samsung HL-P5663W 56" Rear Projection HDTV
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
Jul 29, 2009 | RCA HD50LPW175 50" HDTV
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV picture fades, then shuts off
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Jun 10, 2008 | Samsung TXF2899 28" TV
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Faded Picture
I would have to say it does sound like the CRT is reaching its end. The thing that points this out that the picture gradually gets a little bit better as it warms up. It most likely isn't worth the cost to fix it.
May 07, 2007 | JVC AV-27230 27" TV
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
79 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
