Question about Compaq Presario CQ60-204NR Notebook
Beeps continously at star up, changed to linux ubunto and same thing, Up dated Bios but the problem remain,, thanks for and advise.
  • Compaq Master
  • 11,800 Answers
Beeps signal a hardware fault. To find out which part is faulty (usually it's the memory) you must start to test the pc by replacing parts one at a time until the beep stops.
Posted on Aug 30, 2010
IBM ThinkCentre M51 does no boots
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
Feb 28, 2014 | IBM ThinkCentre M51 PC Desktop
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
Toshiba Satellite P300 makes loud beeps (alarm) at startup and could not move files on the desktop
If your experiencing beeps. Heres what you must do.
  • Count the number of beeps
  • Beware if its long or short beeps.
  • Also take note if its a continous beep
Now after knowing this things. Go to this site. BIOS BEEPS
Now on that page you will see all the bios beep codes. Remember what you did before going to this site.?Take a look for that beep code and at the description of it. you will see what device or what problem you are facing right now.
Good luck, Hope i help. Please give me feedback regarding my solution.
Jul 05, 2011 | Toshiba Satellite Pro P300 Notebook
I would like to dual boot linux on my xp with sp2 i dont know wut bios i have or mother board but i have a compaq presario SR5310F processor intel pentium Dual-Core E2140 i need to figure out if my bios is...
yeah it should be okay, just get a linux cd like susie or ubunto and makesure you have another partition to run it on , however you can run it without installing it just playing it from a CD. I suggest you go to this link for more info:
http://www.linux.org/docs/beginner/install.html
Mar 02, 2009 | HP Compaq Presario SR5350F Desktop PC...
Continous beep every 6 seconds
There is either a problem with your memory or your BIOS settings. Did you recently change any settings in your BIOS? If so try resetting it. You may refer to the motherboard user Guide for help regarding resetting your BIOS/CMOS settings. If you cant find it you may also try to remove the CMOS battery on your motherboard for a few hours and then connect it back this should have reset your BIOS.
If you are sure you havent changed any settings then there may be a problem with your RAM or the slot in which the RAM is connected. Check it by using a spare slot on your comp. If it does nt work then you may have to replace your system RAM.
Oct 27, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I need to know the signs of a BIOS failure
you should be getting error messages
Oct 09, 2008 | Computers & Internet
Fujitsu-siemens Amilo pro v3515 Pent T2080 linux installation problems
please i want the all drivers download for fujitsu siemens amilo pro v3515
Apr 01, 2008 | Fujitsu Siemens CELSIUS Mobile A Notebook
Won't Boot
how much beeps it doing 1-2-3-4????
Nov 09, 2007 | IBM ThinkPad T23 2647 Notebook
Compaq Presario CQ60-204NR Notebook Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
