Question about HP PSC 1210 All-In-One InkJet Printer
Do addresss labels on hp psc 1210 printer I have
Do addresss labels on hp psc 1210 printer I have purchased sheets of labels 64x33.8 24 labels per sheet 3 across x 8 down Avery inkjet code J8159 or L7159 I have been given a list of 200 addresses and these are in a file used by someone else probably a laser printer. If I could reorder the labels slightly?
ronaldsuboc
  • 449 Answers
SOURCE: driver for hp psc 1210
hello!!!
here you can download
the printer driver of your
click here
Posted on Sep 20, 2008
FixinFax
  • 3085 Answers
SOURCE: Label misalignment for 14 label per sheet
Open the rear door and clean all rubber rollers with alcohol
Posted on Jun 27, 2009
  • 71 Answers
SOURCE: c6180 will not print labels as set out in the
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Posted on Aug 09, 2009
techresolve
  • 109 Answers
SOURCE: PSC 1210 All-In-One InkJet Printer: hp psc 1210 all in one drivers...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=90764&
follow the above link it will guide you to the driver
Posted on May 06, 2010
  • 1751 Answers
SOURCE: I have HP PSC 1210
uninstall your printers software
from printers menu
and reinstall it
by running first setup
you can find the software that you need here
just chose operation system and language
hope i help you
Posted on Oct 31, 2010
Got hp psc 1210 all in one at yard sale don't know how to put papper in, how do you put papper in?
Please refer to the illustrated picture below:
Put the blank paper in/through the (labelled IN) Lower Tray/passage, and the printed paper will come out from the Upper Passage (Labelled OUT).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP PSC 1210 All-In-One InkJet Printer
Driver for hp psc 1210
hello!!!
click here
Sep 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 printer, scanner
I presume you used the software disc which came with your printer. If so I would suggest that you go out to hp.com support and check for updated downloads for your machine. Once they are installed you should have it solved. The scanner requires extra software in addition to the printer stuff.
Aug 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Install hp psc 1210
lost my cd for my printer hp psc 1210 where can I download for free
Aug 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet print problem
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Jan 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
i need hp psc 1210 driver for windows vista (64 bits)
Oct 01, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
