Invalid character this the error 2- code : 800A0408 3- to Microsoft vbscript
  • 808 Answers
Its error in ur windows critical section so make ur registry clean using reginout registry it will solve ur problem
Posted on Aug 30, 2010
Comcast code
Good code. What about..?
Good luck
mai
May 15, 2017 | Microsoft Computers & Internet
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; Trident/4.0; GTB6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729;...
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reginout
Sep 23, 2010 | Microsoft Internet Explorer 8
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Everytime i open iternet windows script host appear with the following data: Line 24, Character 1, Error permission denied, Code: 800A0046, Source:Microsoft VBScript runtime error. Please help me to solve...
It is a Windows Internet Explorer bug that could be fixed by upgrading your IE to version 8. Also, check your "home page"found at Tool => Internet Options and set it to some legitimate website. The error message simply means that the page you are viewing has scripts that return an error.
Feb 02, 2010 | Computers & Internet
Web page errors
if you're using IE8 try the compatibility view,
Make sure that the page displays correctly within ie7 or ie6.
Let me have some feedback
Regards
GeWiz.
Jul 21, 2009 | Microsoft Internet Explorer 8
VBScript compilation error ''800a0408''
The Symptoms you get The script does not execute as you had hoped. Instead you get a WSH message box.
The Cause of error 800A0408 Your VBScript contains an illegal character, often at the beginning of a line. It can happen if you copy the script from word, then paste into notepad. For example, to 'Rem out a line we need the apostrophe, which is ASCII character 39; however if you paste from word you may get ASCII 96 (Grave accent).
Note the clue Source: Microsoft VBScript compilation error, this means a syntax error in your script.
The Solutions Check the punctuation marks in your VBScript, particularly look out for apostrophes and commas that do not display correctly. The reference to Line: 1 Char 1, means that the very first symbol that is probably wrong.
Mar 13, 2009 | Microsoft Computers & Internet
Errors found:Code 8024402C Windows can't check for updates
Description:
The 0×8024402C error code occurs because an incorrect character exists in the proxy override settings.
Possible Cause/s:
1. Incorrect character exists in the proxy override settings.
2. A misconfigured Proxy/Firewall can cause this problem.
3. You are trying to access Windows Update using VPN. The website and Automatic Update may not function properly.
4. The corporate environment does not have autoproxy implemented.
5. Your workstations sits behind a Microsoft ISA server.
Resolution 1:
Remove invalid characters from the proxy exception list and then clear the proxy cache:
1. Open Internet Explorer.
2. On the Tools, select Internet Options.
3. Click on the Connections tab.
4. Click on the LAN Settings.
5. Click on the Advanced button.
6. Please delete any entry in the Exceptions section.
Next, clear your proxy cache:
1. Click on Start, and then click Run.
2. Type cmd in the Open box to get a DOS prompt.
3. Type proxycfg -d at the command prompt, and press Enter.
4. Type net stop wuauserv at the command prompt, and press Enter.
5. Type net start wuauserv at the command prompt, and press Enter.
6. Now try the site again.
Resolution 2:
Reconfigure or update your firewall program:
1. Double-check the Proxy/Firewall settings. Add the following urls to the exception list within your Firewall/Proxy:
http://*.windowsupdate.microsoft.com
https://*.windowsupdate.microsoft.com
http://download.windowsupdate.com
Resolution 3:
VPN and Proxy.
Autoproxy is not picking up the wpad.dat proxy configuration file to determine the proxy to be used for the target URL. Thus we are going with no proxy!
1. Try to access Windows Update while not using VPN connection.
2. Use the proxycfg tool to specify a proxy server to use (proxycfg.exe -p <proxy server>). (contact your network administrator to find out the name and port of this proxy.)
This is every possible cause and solution for this error code and how to fix it. Please take the time to rate this Fixya for me for spending an hour researching every possible cause and solution for this code you posted for free, even if you don't figure it out. The solution to your problem is definitely here so read it carefully.
Jul 30, 2008 | Computers & Internet
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Computers & Internet Logo
David Payne
David Payne
