Question about Stoves Ovens
I live in Greece and I have a K├Ârting fan assisted oven cooker white in color. The cooker knob has a mark of 1 (the lowest), 2 and 3 (the highest). For the oven knobs only the timing knob has figures on it, but the oven knob has wiped out. I don't even know its' model. Can you help me with instructions or manual on how to operate the oven knob? Thank you
  • katenidis
    katenidis Jan 26, 2013
    I ALSO LIVE IN GREECE AND HAVE KORTING FAN OVEN WITH PUSH-IN BUTTONS MOST FIGURES ARE WIPED OUT. CAN NOT FIND REPLACEMENT.
  • judem
    judem May 27, 2014
    Me too in Cyprus
barkencoa
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
  • 1250 Answers
SOURCE: hi, ive just been given a smeg fan oven, but there
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Try this web site. If this is not your oven, reenter the correct model number in the box on the left and it should provide the correct manuals. It will also ask you to specify the language you want the manual in.
Hope this helps.
If you find the model number and have trouble with this site, let me know and I'll give you a hand.
Posted on Jun 16, 2009
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
barkencoa
  • 3463 Answers
SOURCE: my grill on my oven is melting the knobs and the
I assume that you are grilling with the oven door open and not closed, if you are grilling with the door closed, then this will cause an overheating problem,if this is not the case, then I would suggest that the grill regulator is faulty,. and needs replacing.
It not covered by health and safety rules.
Please leave any comments you may have, as I like to know if my comments are appropiate.
Thanks.
Posted on Nov 25, 2009
barkencoa
  • 3463 Answers
SOURCE: delonghi esf461st built in fan oven. No operating
The setting with the fan is fan only function.
The setting with the fan and circle is for fan and element for heating the oven.
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
Testimonial: "thank you very much. Now fully operational."
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
I have a kenmore mark 1 oven in my apartment and the oven temperature says 1-9 instead of going in degrees such as 100, 350 etc. I am wondering which number stands for which heat?
This Conversion table is from the old Gas Mark scale
I'm thinking it should be right or at least pretty close.
You could also get a cheap ($5-7) oven thermometer from local grocery store.
Put it inside oven to check actual temp achieved.
Gas mark Fahrenheit Celsius
1⁄4 225° 107°
1⁄2 250° 121°
1 275° 135°
2 300° 149°
3 325° 163°
4 350° 177°
5 375° 191°
6 400° 204°
7 425° 218°
8 450° 232°
9 475° 246°
Apr 10, 2011 | Ovens
I have just purchased a new electric cooker. The old one had three terminals in the back, one each for live, neutral and earth. The new one has three marked live, two marked neutral and one marked earth. I...
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Nov 09, 2010 | New World 70TC Electric Single Oven
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
I need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
Jan 28, 2010 | Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Hi.
Nov 19, 2008 | Ovens
ARISTON OVEN
I have two sources that give correspondances between thermostat numbers and temperatures.
This is the first one:
THERMOSTATS
bullette1.gifThermostat 1 30°C - 85°F bullette2.gifThermostat 2 60°C - 140°F bullette1.gifThermostat 3 90°C - 195°F bullette2.gifThermostat 4 120°C - 250°F Gas mark 1/2 bullette1.gifThermostat 5 150°C - 300°F Gas mark 2 bullette2.gifThermostat 6 180°C - 350°F Gas mark 4 bullette1.gifThermostat 7 210°C - 410°F Gas mark 6 bullette2.gifThermostat 8 240°C - 460°F Gas mark 8 bullette1.gifThermostat 9 270°C - 520°F Gas mark 10
The other one is a formula: t = 20 X (T + 3)
where t is the température in °C
T is the thermostat (1, 2 ... 12)
As you may discover, each of the methods give slightly different results. Hope this will help.
Nov 14, 2007 | Ovens
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
223 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
