Question about Kicker KX200.4 Car Audio Amplifier
No sound hi my kicker kx200.4 amp does not put out any sound, the red light on top is all lit up and the led on the side glows green which i assume means everything is ok but obviosaly it isnt does any one have any idea, im pulling at threads now.
  • shorty69 May 12, 2008
    hi thanks for your feedback but none of it worked, no current through speaker wires, can an amp overheat or suffocate?
    and if so would all the lights still work
    Genius:
  • 1,224 Answers
Did you set your gains and base boost also when you put sterio back in dash did you put rca's on proper outputs or the rca's could have pulled out when putting back in
you have high output and low output
are your subs getting sound to them at all any current going threw speaker wires to subs
radio settings might not be set to back end for subs this is a feature on most receivers to shut off back end subs
Posted on May 09, 2008
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
Kicker 250.2 amp, I have green power led, but the red led on top of the unit does not come on, nor does the red protection led, hear a click out of the subs on occation but nothing else, looked inside and...
Sometimes clicking, or popping sounds from subs are caused by over excursion of the subwoofer, wich can be caused by ultra low frequency, or going below the tuned frequency of your enclosure.
Aug 12, 2009 | Car Audio & Video
Kicker zx1000.1 the green led turns off and the red is lit
check your wiring make sure it is not grounding out check you sreaker wiring make sure they are not reversed +to- make sure it has plenty of air ti breath make sure your speakers are wired for two ohms or four it is not stable for one ohm it has a circuit protection if any one of these thins are happening it will kick the red light on and shut down.
Mar 22, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
KICKER AMP
sounds like a bad ground or power.
Jul 12, 2008 | Car Audio & Video
No Sound No Power
It sounds like part of the power switching circuit has failed. Your options would be to have it repaired/replaced or to try to repair it yourself. If you want to try to repair it yourself, visit the following link and then respond here. You will need to have the amp powered up and you'd need a multimeter to measure the voltage at several points on the board. A good quality photo of the circuit board would be helpful.
Basic Amp Repair
Mar 27, 2008 | Legacy Audio ICE LA798 Car Audio Amplifier
Red light is lit on my Kicker KX400.1
the water shorted it out. It will need to be repaired.
Sep 10, 2007 | Kicker ZR600 Car Audio Amplifier
Kicker KX200.4 Car Audio Amplifier Logo
98 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
