Question about Gaggia Titanium Espresso Machine
Coffee Beans Empty - but the hopper is full!
The grinder whirs around as if it was grinding beans for about 20-30 seconds but then it just stops and reports a "coffee beans empty" on the display.  I have vacuumed out the grinder to remove any possible stuck material, this seemed to worked once, but now it just isn't working.
Help!
  • 833 Answers
Caffeind...the problem is likely still some bean remnants stuck in a switch which is causing the problem. Get some newspaper and open it up on a flat surface. Invert the grinder and give it a couple of thumps on the newspaper. The chips should loosen up and fix it. Remember, beans are both sharp in shape and oily in makeup...perfect for getting stuck.
Posted on May 09, 2008
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Grinder does not stop
I need more information to solve this.
If you mean the grinder just spins but doesn't seem to be grinding anything - and then after 30 seconds or so it tells you the bean hopper is empty - then the problem is sticky, oily beans that aren't sliding down into the grinder.
You want to buy freshly roasted (roasted less than a week ago) beans. Coffee beans from the supermarket are old, stale and sticky with rancid oil. Even Starbucks and Peets - although the sign says "roasted daily" if you read the fine print, the beans in the store are rotated out 90 days after roasting. The oils turn rancid and get sticky after a couple of weeks so you really need to get beans from a local roaster or order them from a roaster who ships them fresh.
I have been using RedBird espresso blend and these beans work perfectly with this machine. They also are the best tasting of any espresso blend I've ever tried. The price is reasonable (cheap even) and the roast date is written on the bag. I get my beans 2 days after they were roasted.
http://redbirdcoffee.com/redbirdespresso.html
In the meantime, until you get some coffee beans that are not oily, you can stir the beans in the hopper. Use a wooden coffee stirring stick or a chopstick and just lift the hopper lid and stir the beans so they slide down into the grinder. You will probably have to do this before each coffee and maybe even 2-3 times just to get one coffee.
Once you get some fresh roasted beans that don't have that oily shine to them you will be grinding without any problems.
Oct 22, 2010 | Gaggia Titanium Espresso Machine
Machine says beans are empty and will not brew.
Try adjusting the grinder coarser when it is running. Either the grind is too fine or the grinds chamber is blocked, remove the brew unit and check the gate to the grinder on the inside right.
Jul 30, 2010 | Saeco Magic De Luxe Espresso Machine
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
May 29, 2010 | Gaggia Titanium Espresso Machine
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
510 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
