My TV screen narrows like )( - Televison & Video
  • Televison & ... Master
  • 17,130 Answers
Fault in the convergence board. Try to solder up the components around the IC , it might release the issue.
Posted on Aug 30, 2010
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
Apr 26, 2014 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Narrow screen
You're discussing about the less in height to picture; I assume. How old is this TV? If it is older than 3 years or so, you have to check all the electrolytic capacitors used at its vertical scan output section circuit. There will be usually 5 or 6 of it. Replace all of it at one time, and check. You have to open the TV, and have to solder these capacitors, and solder with new ones in place. It will be better to contact any service technician. The components said above won't cost more. Mind about the service charges. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Quasar SP-2725 27" TV
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Screen shrinks down to a narrow band of light in
You have bad grounds on the vertical IC. The grounds will need resoldering and check for weak caps near the ic.....they will overheat the ic...creating the bad grounds. Solder will expand and contract with heat and cooling of a tv. HMMMM you could also have a cold solder elsewhere on the board. Search and you shall find.
Aug 16, 2009 | Televison & Video
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Narrow screen
the problem of your tv is in vertical section ,if can locate a trimer( vertical position) try to adjust it and see the effect on screen.
Oct 18, 2008 | Hitachi C29-F100 29" TV
Toshiba 27" standard def. TV
white narrow lines mean at the top of the screen called top retrace lines it is due to vertival section. any high value elec. cap might be defective.
Sep 13, 2007 | Toshiba 27A34 27" TV
TV SCREEN PICTURE SMALLER
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Jun 04, 2007 | Bush 5693D 24" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
