Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Epson Status Monitor 3 says "Printer is not ready" while everything seems to function ok
  • Epson Master
  • 17,130 Answers
Remove printer, uninstall software and then reinstall the software in the PC. Now connect back the printer and get the new harware detected to be installed.
The printer must function well or else there is a fault in the mother baord of the printer.
Try to use maintenance to clean head.Open properites of printer to check on ink properties if low replace ink and reset as before.
Posted on Aug 30, 2010
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
My windows xp can't find my epson stylus nx125 printer driver
You can get them from EPSON website and install them:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=150186&prodoid=63088088&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=20&y=10
Just choose what youi want, a complete (40MB), or Driver only (8MB)
Drivers and Utilities Combo Package
Windows 7 32-bit Edition, Windows Vista 32-bit Edition, Windows XP
epson13804.exe - 40.9MB - posted on 09/15/10
This file contains everything you need to use your Epson Stylus NX125 and NX127 with Windows XP, Vista 32-bit and 7 32-bit.
This combo package consists of the following items:
  • Printer Driver v6.72
  • Scanner Driver v3.770
  • Epson Status Monitor 3
  • Event Manager 2.40
Driver only:
epson13802.exe - 7.9MB - posted on 09/15/10
This file contains the Epson Stylus NX125 and NX127 Printer Driver v6.72. The Epson Status Monitor 3 is incorporated into this driver.
Please leave rating if it helps.
Jan 20, 2011 | Office Equipment & Supplies
How to reset ink counter for a epson R230
The page counter cannot be set back to 0.
The ink levels on your computer is automatically checked and displayed through the Status Monitor
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Sep 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Unable to operate epson stylus office B40W Vista due to blockage of printer by epson status Monitor 3
EPSON Status Monitor 3 displays detailed information regarding the following:
1.Current Status:
2.Ink Levels:
3.Ink Cartridge Information
Please follow the error message prompt, seems like that you need to replace the cartridge for the printer.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Sep 26, 2010 | Computers & Internet
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
Everytime I hit print I get a box saying Epson Status Monitor 3 Could not find specified file.
Go to the start menu and look at your programs under Epson and uninstall the status monitor 3 you don't need it to print. If it's not there try to find it in the uninstall programs under the control panel. If you get rid of it your printer should still print fine you just won't get all the messages from it. You can still do everything you need from the front panel. Just download the user manual from Epson.com You can still download the status monitor 3 from Epson if you really need it, but it may not work because of the previous installation.
Aug 25, 2009 | Epson Stylus 880 InkJet Color Printer
Status Monitor 3 has stopped working on Epson D92 printer.
Have you tried uninstalling Status monitor 3 and the printer driver thenre booting and reinstalling the latest versions from scratch. It helped me.
Apr 01, 2009 | Epson Stylus D92 InkJet Photo Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Status Monitoring
Hi-
Status monitor 3 is not compatible with VISTA operating system. I called Epson regarding this and there is no update and fix for it.
Hope this helps
Jul 02, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
148 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
