Question about Toshiba Satellite A75-S226 Notebook
Having problems with the keyboard, some keys - mainly on the left hand work ok then as soon as I press say k I get a continual line of \\\\\\\\\\ s I had this problem some time ago and ended up fixing it by adding a seperate keyboard to it....then after some time I discovered that it had righted itself and would work without the external keyboard, so I took it off and had been using it ok for ages...then suddenly this has happened. I went into Toshibas Help manual on that p.c. (managed to get into it by selecting with the arrow key) and read about the Function keys etc and tried many different combinations of the function keys (1-10 plus the function button down on the left), hoping that somehow this would fix it...but NO it didn't.. I'm writing to you on my main PC upstairs and havent tried that one as yet. BUT its very important that I get it fixed as I use it for work etc..thanks.
  • 2,567 Answers
I believe your laptop's keyboard has gone bad & needs to be replaced. Try searching with your laptop's make & model in ebay.com. You might find a cheap brand new keyboard.
Posted on Aug 30, 2010
The numbers 1-3 on the keypad wont work
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jun 03, 2010 | HP 48gx Calculator
NUMBER 8 BUTTON WON'T WORK
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
May 27, 2010 | HP 48gx Calculator
My HP48Gx has a problem with the last keyboard column(F L R X arrow / * - +). It stops working and if you shake it then it will work again. Any ideas?
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
Feb 04, 2010 | HP 48gx Calculator
Have a 48GX that stopped working, placed new doubleA batt no response... Note a wird meshed blue line at the center of the screen... Thx jsd
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Sep 15, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
Problems with the keyboard
Sticky keys can sometimes be fixed by hitting right shift key 10 times quickly (I'm not lying!!), and or the culprit key (x) the same way. Try that and if it doesn't work, reboot and type. If it continues, please try another keyboard.
Nov 20, 2008 | Computers & Internet
HP 48GX problem
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 03, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
Screen Problem with my HP48
Hello Francisco from the land of Pablo Neruda and Salvatore Allende!! Salud.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
PS Except for a few minor errors in capitalization ( the pronoun I should always be capitalized), the occasional missing pronoun (I), and the adjective which is invariable (no agreement with a plural noun), I would say that your English is fantastic. It is better than the BROKEN ENGLISH written by the vast majority (95%++) of the human race, native speakers included.
I wish my Spanish were as good as your bad English.
Apr 01, 2008 | HP 48gx Calculator
Green keys on bilingual (EN FR) keyboard
Finally I figured it out. Hold the shift control function keys at the same time. This will turn the green key function on and off.
Feb 18, 2008 | Acer NSK8458AN Keyboard
Toshiba Satellite A75-S226 Notebook Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
