Question about Microsoft Windows XP Professional
Problem in shutting douwn the computer
I use widowsXp service pack 2.when i shut down i get WMS Idle,WOWEXEC.exe are not responding.(end processing). what should ido?
    President:
  • 1,257 Answers
After searching a lot on internet ,at last i have found a link for you to help you to shutdown windows when its not responding,
http://www.mydigitallife.info/2006/10/31/fast-shutdown-faster-windows-2000-windows-xp-windows-2003-and-windows-vista/
you have to make some registry changes and it's done .window will shutdown..
If this answers your question please rate this as fixed.
THANKS
Posted on May 08, 2008
  • Deeps . May 08, 2008
    You can use this simple process to resolve the issue
    Apply the following registry hack to speed up windows xp.
    1. Open regestry editor from Start -> Run -> type regedit
    2. Find HKEY_CURRENT_USER\Control Panel\Desktop
    on the left side of the registry editor window.
    3. Double click on AutoEndTasks key from the right window and assign the value to be 1. The default value is 0.
    Reverting the process is also very simple. Just change the AutoEndTasks value to 0.
    THANKS
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
I am trying to uninstall webroot spysweeper with antivirus but cant find it to remove it, what should i do?
Under normal circumstances, like any other Anti-Malware software, Webroot will protect itself. You cannot randomly shut down its service. You cannot use most external uninstallers.
Always try to uninstall it using Add & Remove Programs first (on XP) or Programs and Features (In Vista and 7), or the uninstall link in All Programs on your start menu.
If you are not able to find it in any of these places, get the official cleanup utility from Webroot directly at:
http://download.webroot.com/SSCCleanup.exe
This utility is made to cleanly shut down and clean up Webroot SpySweeper, Antivirus, and Internet Security Essentials and will even remove itself when it's done.
Dec 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Displays sys error session manager initialization terminated unexpectedly status of 0xc00026c (0x00000000 0x00000000)
smss.exe is the process that manages sessions in Windows Computer. This is the session manager subsystem, which is responsible for starting the user session. This process is initiated by the main system thread and is responsible for various activities, including launching the Winlogon and Win32 (Csrss.exe) processes, and setting system variables. After it has launched these processes, it waits for either Winlogon or Csrss to end. If this happens normally, the system shuts down; if it happens unexpectedly, smss.exe causes the system to stop responding (hang).
In this case, I suggest that you start the "smss.exe" process manually from the Task Manager. You can press the "Ctrl+Shift+Esc" together to display the Task Manger window. Then, click on the Applications tab then the "new task" tab located at the bottom. In the New task dialog box, please type "smss.exe" and click OK.
However, you can also perform System Restore to restore the Windows System files to the time when it operated normally. Performing System restore will not delete any saved data however, all the installed programs after the selected restored point will be unistalled and require to reinstall them.
Jul 11, 2009 | Computers & Internet
You may be a victim of software counterfeiting
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:\Windows\System32.
2.5)
Delete wgatray.exe from c:\Windows\System32\dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINE\SOFTWARE\MICROSOFT\WINDOWSNT\CurrentVersion\Winlogon\Notify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINE ADVANTAGE NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEAT THE DAMN PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START
--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When u use this option whenver your system detects any new WINDOWS UPDATE choose the updates which u want to install... DONT INSTALL WINDOWS XP SERVICE PACK --3.
May 05, 2009 | Microsoft Windows XP Professional
I m unable to shut down my inspiron..............every time i does it , it gets stuck......& i have to shut it down by power button......plz help me out
You have a process that is not shutting down,Try this,Hit control,Alt,Delete and open the task manager,On the process tab,you can see what is running,End task on everything BUT Explorer.exe,logon.exe,and The svchost.exe(you will have a bunch of these)After you have end task on everything else,Try and shut down.
Jan 06, 2009 | Dell Inspiron 710m Notebook
Windows XP shutdown
The computer is just doing it's internal diagnostics before it shuts down. This uses fairly little amount of physical memory. Every computer handles it differently depending on your configuration. If the computer does shut down on it's own....there is no real problem present.
Feb 22, 2008 | Microsoft Windows XP Professional With...
Pc shutdown
Is there any inforation on that window or an error code. Have you install aything recetly?
Oct 20, 2007 | Computers & Internet
Computer says nt authoritysystem
Hi, it sound to me like you have a heat problem.
Check your heatsink fan on the processor and also clean out all dust from the haetsink and motherboard.
Regards mistyman
Oct 10, 2007 | Intel Motherboard
Prob in PC
Are you using an installer with SP2? check your devices under my computer if all are ok.
Sep 20, 2007 | Microsoft Windows XP Professional With...
Photoshop 5.5 & 6.0 wont open or install
This would probably from a corrupted Installation. Try Uninstalling your product first then reboot your system. Retry installing from your installer afterwards. If this does not fix your problem let me know.
Sep 13, 2007 | Adobe Photoshop 7.0 for PC
Microsoft Windows XP Professional Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
