Cold water will not come out at wash or rinse cycle.When timer gets to rinse cycle it stops because its cold rinse only. Ive already taken off cold water hose to back of machine to check for a clog and to make sure adequate water pressure is there. Still doesnt work.
    Scholar:
  • 59 Answers
The solenoid inlet valve has failed. A new cold water inlet valve will need to be fitted. Oficially you should employ a qualified person to do this. It is in the machine where the hose connects.The make and model can be extracted from the plate probably at the back of the machine to identify the correct part. www.thewashingmachineman.webs.com for easy contact
Posted on Aug 30, 2010
Fix washing machine
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 31, 2015 | Admiral Washing Machines
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
TIMER
Mar 25, 2015 | Bosch Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer does not finshing washer
    i aussume you have cold water,,,washers rinse in cold water.if you have cold water ,,replace the lid switch..part # 285671,,lid switch...onthejob
    Jan 23, 2009 | Kenmore Washing Machines
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
