I replace the caps pluged the set in and it clicks, then same blinking light what do i do?
Did you plug it into your ****? worked with your sister, adam :)
Posted on Jun 14, 2011
Philips dcr pixel plus no picture red light how to fix?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Apr 26, 2014 | Philips Televison & Video
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
Set is getting power, but no sound or picture. we purchased it black friday
Power supply issue such as bad caps etc. But need the model number of the set in order to assist further.
Feb 08, 2012 | Hisense Televison & Video
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My Mitsubishi WD-52527 has a constant blinking green light. There is no video and no audio just a blinking green light when it is pluged in
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options for you.
1. Have it fixed by a professional 2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It'scalled: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.Kaufman605
Dec 11, 2010 | Mitsubishi WD52527 52" Projection HDTV
Set is dead
Replace the Horizontal Output transistor and High-Voltage Transformer.
Set will come on, if it goes back off,solder around the switch mode power supply even if it looks good.
Carlos
NMHS Health Services Audio Visual Department
Jan 16, 2009 | RCA 32V430T 32" TV
Lcd 17" veiwsonic power problem
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
17" lcd veiw sonic power blinks
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
