Question about Imation SpongeBob SquarePants Npower 15 in. LCD TV
I ran the Npower DVD player with this LCD tv but the picture keeps going out. I was wondering if that was a defect or a reason that it happens?
I have a spongebob squarepants dvd player and it keep skipping the dvd
Posted on Feb 18, 2011
What is the best dvd player for a sceptre 32 lcd hdtv
Yes, an hdmi connection is the very best. However, if you are not able to connect your dvd player the other way, just choosing hdmi or not might not solve your issue. Hdmi connections allow upconverting and thus a higher picture quality for you.
Dec 01, 2012 | Sceptre X240BV-FHD LCD TV
Second screen not working for dual dvd player
see the diagram and test it:
some block inside can be defective, however tight any wires connectors inside, you must open the DVD.
if you can not do it go to the repair shopt TV for fix it
God bless you
Jul 20, 2012 | Philips Televison & Video
My Westinghouse TV LCD has no sound but has picture please help? 32 LCD westinghouse
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Oct 21, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Have picture no sound
Regards.
Walesarumi
Sep 28, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
We have a FLX 3210 and we have a picture but no sound....
Regards.
Walesarumi
Sep 28, 2011 | Element Electronics FLX3210 32 in. LCD TV
Picture keeps flashing off and on. volume goes through dvd player so it goes into mute when this happens. This happens for 5 to 10 minutes at a time
change the dvd player and see what it does it could be your dvd is faulty.or check the wires that goes from the dvd to your tv.maybe they are kind of broken.or try the tv alone with your cable.good luck.
Sep 23, 2011 | Sony BRAVIA KDL-46XBR8 46 in. LCD TV
Has sound , but picture is dim and red looking
First, connect the TV to a DVD player and observe if problem will still be there. If problem persists, then it mean the fault is from your TV's LCD inverter. Sometimes, a defective video cord can cause this type of problem, this is why I asked you to connect the TV to a DVD player.....
Your TV has a long board that is called LCD inverter board. This board is defective or dying.
This long LCD inverter board's only job is to provide the TV LCD screen panel to have a back-light to the LCD screen panel to produced a picture.
Try websites like shopjimmy.com, ebay.com to buy a refurbish long LCD inverter board for the replacement.
If you are not a TV expert, please take the TV to a repairman for the LCD inverter replacement. This is not expensive to fix...
Note that TV store current, so wait for some minutes before attempting to open the TV's back cover.
Regards.
Apr 15, 2011 | LG 42PC3D 42 in. Plasma Television
Toshiba 22lv505 TV/DVD Region Code Error
maybe the spindle motor is turning defect causing not to spin the disc naturally,its time to have to check that to the Toshiba service center
Jun 20, 2010 | Toshiba 22LV505 22 in. LCD TV
Our picture has like shadow lines going through
Check first if this happens if you are using dvd player or a playstation. Check if using different cables or ports helps.
Dec 07, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Imation SpongeBob SquarePants Npower 15 in. LCD TV Logo
71 people viewed this question
Top Imation Televison & Video Experts
Electro Med Services...
Are you an Imation Televison and Video Expert? Answer questions, earn points and help others
