Question about Brother MFC 210C All-In-One InkJet Printer
Have an Error 51 on Brother MFC-210C all in one printer?
  • 4 Answers
Mine had the error 51 and after looking at everything in this FixYa, mine had a broken spring on a rod back behind the printer head. Look for that and it might help you. Took me several hours of researching
Posted on Nov 17, 2012
  • 2,335 Answers
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Posted on Aug 30, 2010
faxman789
  • 297 Answers
SOURCE: Brother MFC-210C All-In-One InkJet Printer ERROR 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart you printer.
Posted on Jan 22, 2009
SOURCE: vista and brother MFC 210C
download the driver click here
Posted on Jul 14, 2008
  • 7993 Answers
SOURCE: Brother MFC-210C USB Printer is not printing Troubleshooting
You try to solve that problem by following the instruction the machine gave you. Here is the link to the manual.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
Hope it helps.
Posted on Aug 30, 2009
voodoomox
  • 1689 Answers
SOURCE: "Unable to clean" error message
reset the printer by leaving it unplugged for at least 2 hours and then boot it back up. this will flash the memory of the machine
Posted on Sep 17, 2009
SpideRaY
  • 687 Answers
SOURCE: how can i clean my mfc 210c printer head maually
The majority of the printer parts like take up rollers and gears can be cleaned using Rubbing (IsopropylAlcohol or aka Surgical Spirit in the UK this will remove ost of the finger grease that can build up over time.
I wouldn't however suggest that you attempt to manually clean the print heads as they can easily be damaged and destroy the printer replacement heads can be as much as a new printer and difficult to change.
I recommend using the deep clean function found in the printer driver maintenance tab, you might have to run it 3 times at least if you don't use your printer very often.
Tip is to always leave enough ink in the cartridges to prevent the heads from drying out, this is why most manufactures tell you to replace ink when there is about 5% left in them to prevent this happening
Posted on Nov 04, 2009
I'm getting the error message Unable to print. check user guide on my brother mfc 210C all in one printer. I don't have my user guide. Please help. Tiare'
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 -defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
"Unable to clean" error message on Brother MFC 210C all-in-one printer.
Sep 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Already purged mfc-210c but the same error
não entendo ingles não poderia mada mensagem em portugues
Jan 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error 51
One or more ink cartridges may be empty. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See page 143 of the manual for instructions on replacing the print cartridge. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C problem
press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
Jan 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210c error code
Sorry, this cant be fixed anymore: Printer engine or main circuit board seriously broken.
You need a new printer (spare part is twice as expensive as a new mfc).
Nov 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,714 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
