Question about HP Mini 1000 Netbook
When I start the system, HP logo will pop up plus F9, F10, & F12. After that, the screen will appear blank. Can you please tell me the cause of this problem? I am not able to use my netbook. Thanks!
    Genius:
  • HP Master
  • 1,354 Answers
Hi
you have prob with your OS
just repair your windows you prob will be solve
if not then your have to reinstall windows
Posted on Aug 30, 2010
Why is it that I am unable to boot from CD? HP Pavilion p2-1394 Windows 8.1, I would like to install Windows 7, my CD/DVD works just fine I have hit either the "F1" or "F10" keys to be taken to the BIOS...
With f8 or f9 you will get into the bootmenu it can also be esc f2 or f12, when in the bootmenu sellect dvd player then it will start from dvd it will give a line, do you want to start from dvd hit any key.
Hop that helped!
Cheers
Jan 16, 2018 | HP Computers & Internet
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
Hi when i satrt up my hp compaq mini 110 it wont load past the bios. it comes up with the options for F9: change boot device order, F10:BIOS setup options, F12: Network boot. if i leave it to laod past...
Check to see if any media is in you CD DRIVE, or any other drive because if BIOS is booting from the CD or other media first, it never gets to your hard drive thus never boots windows. If clear, Press F9 and enter into your BIOS setup. You will have to make sure your boot sequence/order is in order to boot first from the hard drive. If all is in order try F8 hitting it repeatedly until safe mode options appear. If this doesn't work post a reply and we'll go from there.
Jan 11, 2011 | Computers & Internet
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
Keeps shutting down.
To resolve the issue, Please perform the following steps:
Step 1: BIOS Reset
To reset the BIOS defaults, follow these steps:
1. Restart the computer and press F2 (F10 in some Notebooks) as soon as the HP logo appears.
2. Go to Exit menu and select Load BIOS defaults or press F9.
3. Go to Exit menu and select Save changes and Exit or press F10.
This will reset the BIOS defaults. Now, when the Notebook restarts, press F8 repeatedly until the start up menu appears. Select the Safe Mode and press Enter Key to enter in Safe Mode and then perform the step 2.
Step 2 : Disable the "Automatically Restart" under System Failure:
1. Click Start, right-click the My Computer icon, then Properties.
2. Click the Advanced tab, then Settings in the Startup & Recovery section.
3. Remove the check mark next to Automatically Restart under System Failure.
4. Click OK to close the Startup and Recovery window, then click OK to close the System Properties window.
5. Restart the computer.
Step3: Reinstall Power management
To reinstall Power Management in Windows XP, follow these steps:
1. Click Start, select Control Panel, and then choose Performance and Maintenance.
2. Click the System icon to open the System properties window.
3. Select the Hardware tab and click Device Manager.
4. Click the plus (+) sign next to System Devices.
5. Right-click the ACPI Fixed Features button and select Uninstall.
6. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
May 25, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
SCREEN WENT BLANK THEN WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPTWINDOWSSYSTEM32CONFIGSYSTEM\r CAME ON THE SCREEN TRIED TO GET INTO BIOS BUT ONLY COMING UP WITH PLEASE WAIT
Dear user,
if you are trying to access bios for setup of CD ROM as a first boot device and having problem to access the bios then here is an advice for you.
most of notebooks or systems have a special key assigned to select the boot device at startup without entering in bios setup. therefore please hit function keys at startup like F9,F11,F12 when you start system. F9 and F12 keys are most commonly used for boot device selection.
hopefully you will understand my advice.
Please dont forget to RAte my solution
Sep 09, 2009 | Acer Aspire 3000 Notebook
HP Mini 1000 Netbook Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
