Question about Lincoln Welding Tools
The wire feed motor on my lincoln weldpac 100 suddenly stopped working.
    Sergeant:
    Champion:
  • 390 Answers
Check the fuses in the machine your booklet will show you where they are
Posted on Sep 02, 2010
Lincoln weld pak 100 welder no dc volage to wire feed motor
If the cooling fan motor comes on and the the machine “clicks” when you close the trigger, use your index finger and push in on the on/off switch, if the feed motor turns replace the on/off switch
Dec 05, 2017 | Lincoln Welding Tools
The blower motor worked then suddenly stopped
At the central junction box, check 15A fuse 16 which feeds the remote climate control (RCC) module. Check 10A fuse 28 which feeds the RCC module and the blower motor relay. Check 40A fuse 6 which feeds the blower motor relay.If the fuses are OK, start the engine (the blower only works while the engine is running). There should be 12V at the PNK/WHT wire connection to the front blower motor speed controller and the blower should be operating. If not, the controller may be defective or the blower motor may have failed
Oct 15, 2012 | 2002 Ford Taurus
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
How is the wire feed cable assy held in place at the wire feed assy on the lincoln weld pack 100?
There should be a thumbscrew or set screw in the portion of the wire feed assembly where it goes through inside of the cabinet that snugs up to the straight portion of the cable assembly.
Dec 25, 2011 | Lincoln Welding Tools
Wire feed motor stop working. When trigger is pressed motor attempts to turn but does so in short choppy intervals. Removed the wire from feed and motor does the same thing.
Sounds like a broken wire in the cable from the trigger to the control board - or the switch in the handle is crapping out.
If it's had a fair amount of use, or has been bent into some seriously oddball or tweaky positions, it might be time for a new feed line and trigger assembly.
Jul 06, 2011 | Lincoln Welding Tools
I have a ProMig 175. Suddenly the wire feed motor does not work. The solenoid clicks. I have manually turned the wheel trying to reposition the contacts in the motor. No help.
Verify the polarity is correct for Flux or Mig configuration (should be on label under lid) - and ensure there are no loose connections on that polarity wire.
Loosen the tensioner + make sure the wire feed motor turns freely by hand.
My WeldPak 100 and SP-135T were tough to turn, but it did turn freely.
If it does spin freely, then inspect the contacts for the voltage selector. Make sure to unplug the power cord and keep clear of the big capacitor. My SP-135T contacts corroded while in storage.
Apr 12, 2011 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Lincoln 100 hd, the wire feed motor is not moving or even making a noise or anything when I press the trigger. I just installed the conversion kit to gas, could I have done something wrong?
disconnect the gun from the machine and the bridge the connector with a piece of wire, if the motor moves then you have a faulty trigger switch. If it does not do nothing then is the pc board.
Dec 25, 2010 | Lincoln Welding Tools
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
I have a sp 100 lincon pull the trigger it clicks, no wire fd
not diode problem,check enternal wiring and relay for feed motor.
Jun 25, 2009 | Lincoln Welding Tools
Welding Tools Logo
119 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
