Question about Cameras
I own a Canon Powershot pro 90 IS with 16 MB CF memory card. I want to upgrade the card. Can you tell me whats the maximum capacity the Camera can take.
    President:
  • 1,335 Answers
The camera can take whichever capacity card your want. Type 1 and 2 CF cards up to and past 16GB are available. It is really what you can afford and how many frames you want to put on a single card before downloading it.
Posted on Aug 30, 2010
Is a SDHC Memory Card 4GB compatible with my Canon Powershot SD600 camera?
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Aug 26, 2010 | SanDisk 4GB Secure Digital High Capacity...
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Hi.. Can you tell me as to what is the maximum CF memory card that can be used with Canon Powershot Pro1
When this model came out a 1GB card was a large capacity card, so Canon's specifications stop there. I talked with a friend who has used a 4GB card in a Pro 1, and it's possible that it may work with capacities even larger than that. But I think you will be able to use a 4GB without problems.
May 07, 2010 | Canon PowerShot Pro1 Digital Camera
Memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
Jun 10, 2009 | Canon PowerShot A75 Digital Camera
Whats the highest capacity memomry card that we can use ?
According to the specifications, this model is compatible with the SDHC protocol for memory cards. I believe SDHC cards come in capacities up to 16 MB now.
Apr 23, 2009 | Canon PowerShot A460 Digital Camera
PowerShot G1 + cf card
The Canon G1 was my first digital camera, years ago. When this camera was sold it came with a 16 Mb CF card. The manual refers to CF card sizes from 8 Mb up to 128 Mb and the number of photos you can take with each size card. However, I bought my camera together with a 1GB "micro drive" (tiny hard drive in a CF card format) and although it wasn't "supported" by Canon, it worked fine. I also used a regular 1GB CF card in it (after I lost the microdrive card). If you want to use a card larger than 1GB with this camera, test/borrow a card to make sure it works before you buy one. Camera stores always have a variety of cards (used to demonstrate the cameras they are selling) that you can put in your camera and test before you decide which card to buy.
Dec 15, 2008 | Canon PowerShot G1 Digital Camera
Can ixus700 upgrade to use 4gb memory card?
The ixus 700 is only specified to be compatible with SD memory cards (and MMC cards). The protocol for SD cards only covers up to 2MB. Cards of higher capacity are the SDHC (high capacity) protocol, but this protocol did not exist when the ixus 700 was introduced. As far as I can tell, there is no way to upgrade to be compatible with the newer protocol.
Dec 09, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Larger Memory Card for PowerShot 300
Use the camera to format the card. Press Menu button, select the tools menu, scrolll down to the selection showing the memory capacity of your card and select it. The "format card?" selection should pop up. Select "yes".
Aug 22, 2008 | Canon PowerShot A300 Digital Camera
Capacity of cf card to be used with a60
According to Canon's website, the limit is 256MB. You could try it with a larger card, though. Nothing bad will happen to the camera, and it should either work fine or not at all. Here is the page from Canon's site: http://www.usa.canon.com/consumer/controller?act=ModelTechSpecsSupportAct&fcategoryid=221&modelid=8774
Feb 12, 2007 | Canon PowerShot A60 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
