Question about Cameras
I get memory card error, is it the card, or something else in camera?
  • 12,061 Answers
Hi, whenever we get a Memory Card Error, usually that is the actual SD card itself, it may actually be faulty, or simply need re-formatting.
The way to find out, is to obtain a USB to SD card dongle adapter, now insert the SD card into said adapter and see if it can be read, if so, copy/paste all files to a safe location on your HDD, then select the drive, right click, and choose Format, Format FAT32. then when finished return it back to the camera, and see if it is picked up, if it is, and it all seems OK, then, remove it once again, go back to the PC and copy back that info you saved before, (If you want) Now once again return to the camera and all should be well. If it doesn't work after this, you have little option but to reformat again, and see if it will work formatted but blank, then, write some data from the phone to it and see if that's OK, as maybe it is the camera that's at fault, unlikely but this will prove it one way or the other. If it doesn't read/write and work, first try another new SD card, before coming to the conclusion the camera is at fault. If it is, then you have no option but to send it in for repair.
Posted on Aug 30, 2010
How can I solve my sony cyber shot camera modal DSC W630 is shows error as C13:01
This error indicates a memory problem.
The camera can't read or write data to the memory card. Try turning off and on the camera again, or take out and reinsert the memory card several times. Also remove and reinsert the battery.
It also can mean the memory card is not formatted, or there is a format error for an other reason. Format the internal memory or the memory card.
It also could mean the memory card is damaged and can't be used any more. Then you have to place a new memory card.
I hope something will help.
This is also in you user manual.
Mar 19, 2014 | Sony Cyber-shot Dsc-w630 16.1mp Digital...
Eos rebel T3ieos 600D canon eror 70
Error 70 is something related to the data being captured and/or written to the memory card is detected as being problematic in some way... this may not be a simple memory card error, although of course that can't be ruled out. Try re-formatting the memory card in the camera.
Jan 01, 2014 | Canon T70 35mm SLR Camera
The message says memory card error....it is a new memory card
Try formatting the card- in most cameras there's a menu option under tools or system or something.
If the camera still can't use the card, try the card in something else (like a computer memory card reader or an mp3 player with a memory card slot). If it always has errors it's probably defective
Jan 15, 2011 | Cameras
Canan 350D with CF error, says no image on screen. How do I fix this?
The memory card could be bad, try formatting the memory card, or the camera could be damaged. Look inside the memory card door, take out the memory card and look at the little pins in the camera that the memory card connects to. If any are bent or missing then the camera will need a major repair to be fixed. This is something for Canon or qualified technician to fix.
Nov 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Panasonic Lumix will not read memory card.
try formatting your cd card in your Fz. If it keeps telling you memory error, try using it in windows, put data on it, to see wether it can hold them and read them too.
Happeded to me once too, format did the job. Just format it in the camera, not your pc.
Vladimir
Jul 01, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Unable to view pics from memory card of lumix camera
hi i think your memory card is dead, just to make sure try it in something else. let me know Yvon chow !!!
Jan 02, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Bought 8gb memory card - error message
Hi, I suspect that the SD card is to big for that camera as that camera is a lower end camera. You should try the SD card in a camera that is known to be able to handle such a huge card.
Jul 21, 2008 | Panasonic Lumix DMC-LS2 Digital Camera
Canon digital camera
maybe something is stuck in the memory card part of the camera...
May 28, 2008 | Cameras
Digital camera error
1. What's the make and model of the camera?
2. What's the make, model and capacity of the memory card?
3. How old is the camera?
Dec 19, 2007 | Cameras
Memory Card Error
Try checking the card slot in the camera. If it is dusty, then it might need cleaning.
Also, the problem could the the memory cards. If you are using a cheap brand, then they might not properly.
I recommend Lexar, Panasonic or SanDisk SD cards.
Nov 14, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
