Question about Electrolux Refrigerators
Though repaired twice, Electrolux Refrigeratotor gas leaking away, no cooling
  • Electrolux Master
  • 17,129 Answers
Before the gas is filled the entire system, the evaporator and the condenser coils must be tested with a pressurised air test to detect any tiny leak in the system.
The system must be powered in and watched over in time to test the leak. There could be corrosion in the coils that has lead to the leak and unless it is rectified there is no use of filling gas.
Posted on Aug 30, 2010
Hi I have a domestic rm3862 refrigerator and it will not cool on gas or elect we replace the elect board and still don't work it get hot not cold
Evaporation fridges are normally reliable and have the advantage of being silent. There is no compressor but there is a heating element that should cause the gas to circulate. Under normal circumstances the fridge thermostat should switch off the heating element when the interior is cold enough and the subsequent heating cycles will be so short the heat will not disrupt the fridge operation.
If the fridge is not cooling the thermostat will not switch off the heater and eventually it will begin to warm the interior.
It will not cool if there is insufficient refrigerant.
It will not cool if there is no refrigerant gas.
In this case it will be because a leak has allowed it to escape.
It will not cool if the refrigerant has settled away from the heating element. This happens sometimes if the fridge has been unused for a time or transported in a non-upright way.
It sounds odd but years ago we had a large American Electrolux evaporation type fridge that was unused for a while and would not work. We were told to take it outside and to spend an hour tipping it over and over. We did this and when we plugged it in it began to work like a brand new fridge even though at that time it was nearly 30 years old...
It was still working when we gave it away five years later.
Oct 24, 2016 | Refrigerators
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Hi, we have a caravan which has an electrolux RM360 gas/electric fridge installed. There is a very weird smell coming out when the fridge is turned on. Its like an ammonia smell it is really strong,
Travel refrigerators use an ammonia coolant instead of freon. So the smell is telling you that you have a leak in the sealed system.
Suggest you look for a replacement fridge OR a rebuilt unit because that is usually cheaper than taking it to a service center for repairs.
Jan 25, 2012 | Electrolux Refrigerators
Split air conditioning sytem- not cooling very well (maybe gas problem). previously had icicles coming out of fan. How much should this cost to repair. 5 year old system.
On average a service call should be around $75 to diagnose what's wrong. If it is low on freon there must be a leak somewhere and will have to be found and repaired before more freon is added. Cost would depend on the amount of time it takes to find the leak and if it can be repaired.
Mar 21, 2011 | Electrolux E23CS75SS Air Conditioner
My 1988 Ford Bronco 5.0 has been stalling / acting like its run out of gas. (Has always run great before) I know it has plenty. Today 7.28.10 It stalled twice, first time it did it had at least 1/4 tank,...
You might have what is called vapor lock. The fuel gets so hot that it boils in the fuel pump or the lines. Do this test spay water on the fuel pump to cool it off . ( this only works for a few minutes before it gets to hot and vapor locks again ) If you can Keep the engine heat Off the lines and the Fuel pump it might help. If you have metal fuel lines near a heat source rap them with something such as rubber fuel line sliced down the middle to keep the heat off them If you are using an aftermarket electric fuel pump relocate it down low near the gas tank ( they work better pushing than pulling ) away from any heat source such as exhaust If your using the stock fuel pump try replacing it with a new one it might be getting weak Replace the fuel filter while your at it.
Jul 28, 2010 | 1988 Ford Bronco
Hi i have an older electrolux 120 gas fridge,the piolet light is going but does not cool down.thinking it needs re-gasing if so where on the sunshine coast and how much
sounds as though this is an absorbtion type fridge and hence no gas! in any case, refrigeration only needs regassing when there has been a leak
Aug 31, 2008 | Electrolux Refrigerators
Electrolux camping fridge not getting cold when running on gas, warm air flows from top vent bottom vent not blocked please help
Does it work o/k on 120v? If it does then you may only need to have the burner serviced which entails pulling the burner and jet apart and giving it a good clean out. If the fridge heats up on 120v but does not cool, then you have a major problem with the cooling system and can be expensive to repair
Swy
Aug 25, 2008 | Electrolux Refrigerators
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
May 28, 2008 | Electrolux Refrigerators
Electrolux RM212,F, wont cool on gas but appears to be ok on electric. The flame lights but can only feel a slight chill in the freezer box, and the flame does not seem to adjust with the control.
May 13, 2008 | Electrolux Refrigerators
Refrigerators Logo
76 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
