I have a panasonic RV26 DVD player. After inserting DVD it goes to the reading mode (normal) but it stays on the reading mode for awhile then code H02 shows and then stops and and will not accept any other command. I have tried, opening and closing, shutting power off while holding down the play button at the same time, fast forwarding, reversing, and cleaning the disc. Nothing happens. HELP!!
  • Televison & ... Master
  • 17,130 Answers
The Optical head or the mother board is defective. The data is not received and so the Mp is not able to read or process.
hence if have cleaned the optical head lens, and there is no reading try to put in a audio cd to test. If the cd is read the head must be Ok and the DVD processing must be faulty possible board issue but if there is no reading then the optica head is faulty
Posted on Aug 30, 2010
When turning on the Panasonic DVD player the unit stays on for 3 seconds and reads "Hello", then reads F61 and turns off. What causes this and how can it be resolved?
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
May 18, 2010 | Televison & Video
I would like to make my Panasonic DVD-RV26 region
Hi
Thanks for using FixYa. There are the following two methods to make it region free---
Method 1:
No disc in tray; Press STOP; Press SET-UP: KEY IN 3, 8, 8, 8, 3 then 0 for zone free
Method 2:
1. Remove DVD/CD from your drive.
2. Press the following keys on your remote: [Setup] [1] [>=10] [6] [4] [3] [8]
3. A new menu option will appear – named other followed by four stars. Use Codes: 3192 -> Multi-Region Enable
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
May 01, 2010 | Panasonic DVD-RV26 DVD Player
Dvd player wont open
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Jan 03, 2010 | Panasonic DVD-RV26 DVD Player
H02 -------stop
moz-screenshot.pngmoz-screenshot-1.pngThis is what i was able to gather for you.
H and than the numbers is the message:
Trouble is likely to have occured. the number following "H" differs depending on the status of the player.
Press {POWER} to switch the player to stand by mode and then back on. alternatively, press [POWER] to switch the player to the stand by mode, disconnect the AC power supply cord, and then reconnect it.
If the error message fails to be cleared even with this action being taken, you will need to ask a technician to repair the player.
you may also be able to call
1-800-211-PANA (7262)
for more troubleshooting and or to find the closest repair retailer.
Dec 27, 2009 | Panasonic DVD-RV26 DVD Player
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Will i be able to use my old panasonic dvd-rv26 for a tv
From the information I found, it does not have an ATSC tuner that you need to pick up the digital over the air TV signals. You will need one that does, check this page: http://www.ezdigitaltv.com/Digital_Recorders.html
Jan 06, 2009 | Panasonic DVD-RV26 DVD Player
Dvd regional codes
I have a Panasonic -RA60 that has suddenly stopped working. Every time I insert a dvd from Block Buster It reads (can not be played in your region) Why? Please help!
May 06, 2008 | Panasonic DVD-RA60 DVD Player
HO2 error
That's the spindle motor and it has to be replaced to solve the problem.
Jan 01, 2008 | Panasonic DVD-RV26 DVD Player
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
