Question about SMC Barricade g SMCWBR14-G (662698582192) Router
HOW TO CONFIGURE THE ROUTER
HOW TO CONFIGUR THE SMCWBR14 G EUA
    Novelist:
  • 144 Answers
Hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly
connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
Posted on May 08, 2008
I use Wireless router Model: SMCWBR14-G2. My Office is use Staitc IP for Staff and DHCP for Customer. But DHCP is well work, static is not. I Re Configure this router. It is Ok!. But Gtalk can not use by...
We have used gtalk with static ip number. Sounds more like the port it uses isn't open. It could be that they block the port at your office. When using static ip numbers the gateway must be the number of the router in order for it to get out to the internet.
Mar 18, 2011 | SMC Barricade g SMCWBR14-G2 Wireless...
I want to know how to configure my smc router to the network ?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Aug 19, 2010 | SMC Barricade g SMCWBR14-G (662698582192)...
Computer wont recognize cable hookup
You will have to start the configuration from the wired network rather than the wireless network. Connect the computer directly to the router. I am assuming you might be trying to configure the router from the wireless network. Then use the installation CD to configure the router
Nov 29, 2009 | Computers & Internet
Need to know how to hook up my router and where the cables go i have the basic idea but need help
Dear,
1. connect the cable from the modem to WAN port 2. configure one IP for WAN port in the sebnet of modem (say 192.168.1.x) 3. Configur differnt subnet to the LAN (say 192.168.0.x), you can enable dhcp server router
This will help you more
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip for any help. feel free to contact
Oct 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | SMC (SMCWBR14-G2) Router
Can I use SMCWBR14-G2 firmware to update my SMCWBR14-G's firmware
SMCWBR14-G Firmware V1.00.28
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_HUN&productCategory=1&modelNumber=1386&partNumber=3083&downloadType=2&knowsPartNumber=false
Jan 02, 2009 | SMC Barricade g SMCWBR14-G (662698582192)...
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Smc router
If you know the part number of your router, you can download needed utilities from this site.
Jul 29, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
Won't connect
http://www.smc-asia.com/download.php?Fullkey=50&Class=4
this url for mamul of your configuration so download the mamul and configure it
Jun 19, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
SMC Barricade g SMCWBR14-G (662698582192) Router Logo
349 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
