Question about Dell Inspiron 6000 Notebook
Wifi problem on dell inspiron 6000
I fully format my laptop, after that every is working well accept for the wireless device. its was INTEL PRO/WIRELESS 2200BG. i already download the driver from dell suport.. but still its not working. i hope you can help me..
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 08, 2008
    Sergeant:
  • 458 Answers
Check the driver properties and make sure it is not turning off when idle. You could have router issues. Are you using a wireless router of your own? Are you putting in the password for the connection. I could go on and on about wireless problems. Wireless does not just pull the Internet out of the AIR like some people think. Get someone to help you that can use wireless and compare settings.
I need to download Microsoft Virtual WiFi Miniport adapter
kemar,
Click the link below to view the youtube video on how to turn your windows 7 laptop into a MS Virtual Wfi hotspot.
http://dell.to/13mQJV6
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2013 | Dell Inspiron 6000 Notebook
I wish to acced of a free setup of wifi dell inspiron 6000
WiFi is part of the wireless network card. There is a wifi button above the keyboard.
Here are the drivers if you need them. Choose the OS, download and run setup.
http://www.dell.com/support/drivers/us/en/04/Product/optiplex-745
The manual - Page 48 for network setup.
http://support.dell.com/support/edocs/systems/ins6000/en/om/D5181bk5.pdf
Dec 12, 2012 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Wifi?
Look on the keyboard and see if it has a key with a symbol for a wireless device. If it does, click it with the FN (function) to enable or disable it.
You can also see if there is a switch on the front or sides of the laptop for a wireless device.
Finally, go to start>control panel>system. Access the device manager. Click the plus next to network devices and see if any wireless devices are listed.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Jan 01, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 not picking up wireless signal
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dell inspiron 6000 wireless driver
Every dell inspiron 6000 drivers can be found on this tool: Driver Update
I hope this helped.
Peter
Dec 19, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
343 people viewed this question
Alun Cox
