HP photosmart C4200 successfully installed and prints only on white paper. Unable to print on conqurer paper.
    Novelist:
  • 57 Answers
The issue that you are experiencing is due to the paper sensor unable to detect the paper type that you are using.
To resolve the issue, Please open HP Solution Center.
Then click on Settings >> Print Settings >> Features Tab >> Set the Paper Size that you are using and the Paper type as "Plain Paper".
Setting the Plain paper is to deactivate the sensor. After Setting the Paper type as Plain Paper, Click on Apply and then on OK.
Again Make sure you Click on Apply and then on OK.
This should resolve the issue.
Regards,
Lawrence
Posted on May 11, 2008
  • 51 Answers
What is the problem - does it feed the paper or just nothing comes out when the paper is fed through to print
Posted on May 09, 2008
When I want to print something, if I go to file then print, it says offline, bot when I click on the C4200 series( copy 1) it will print BUT brints VERY small. Am I supposed to doing something...
  1. Click start --> Control panel --> Printer and faxes
  2. Right click on printer 'C4200 series' and select 'Set as default printer'.
  3. Right click again on the same printer icon and select 'Use printer Online'.
  4. Try Printing.
  5. You can delete the icon that says 'C4200 series(copy1)' if you are not using it.
Regards
Riztech
Oct 24, 2010 | HP Photosmart C4280 All-in-One InkJet...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
HP photosmart C4200 - alignment disable
I've run into this problem. The first simple thing to look at is the aligment page itself. Does it have colors on it or is it strictly greyscale/black and white? If your color cartridge is empty/a knockoff/not installed correctly, the printer will just print the alignment page in black/white and not necessarily notify you of a problem. However, the cartridges won't align if the aligment page isn't printed in color.
This is clearly a screw-up by HP, because there is nothing to notify you of this problem in the software or manual. The printer will automatically print an aligment page, and then tell you to scan it. If they did it right there would be some error message notifying the user that it couldn't print an aligment page rather than print one that is worse than useless.
Sep 03, 2009 | Office Equipment & Supplies
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. The following occurred when I tried to troubleshoot: Network Diagnostics was able to connect to the...
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. My HP icons are no longer in menu bar either. When I try to print the HP makes a loud noise and shoots the paper through at rocket speed with terrible print quatlity.
Aug 30, 2009 | HP Photosmart C4280 Aio Printer
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
Can not print
try this link http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3619474&lang=en
Nov 23, 2008 | Lexmark X83 All-In-One InkJet Printer
Summary page
hi dear,
it's not from your printer...but the information from your microsoft word, opening your word document, choosetools, option choose print
oke release a mark from document properties
oke
print again
goodluck
cropp
Mar 27, 2008 | Office Equipment & Supplies
200 people viewed this question
jasbo
jasbo
