Question about Casio QV-R40 Digital Camera
Camera is switching off and saying battery to low, even with new batteries. I can view the pictures already taken and the little battery picture on display screen does not show battery is low, it will jst do that and switch off when I try to take a Photo. Thank you.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 30, 2010
My Cybershot DSC-S650 has recently won't stay on. I have changed the batteries to different types. The only way it comes on is if its in viewer mode to view the pictures that I have taken. I have even...
My HDC-570AB Hitachi digital camera drains AAA batteries as soon as I switch it on so that batteries are running low within 2 minutes of taking pictures. It renders the camera useless unless I take out an endless supply of AAA batteries! Is there a solution to this?
Sep 13, 2011 | Cameras
Hi, when I click on the button to view pictures the camera switches itself off. Also if I click on the tool box menu the camera switches itself off. Also if I connect to my PC it doesn't see the camera -...
Have you checked the batteries on the camera? Weak batteries will shut the camera off any time ther is a call for power that exceeds the charge left in the battery.If after you change or charge the battery and you are still having this issue let me know and we can go from there.
Please use Sony Cyber-shot batteries for DSC-H2 model camera
If your camera keeps shutting down and not allowing any pictures to be taken, use the 3 pixel setting. It may allow you to get at least some use out of the camera. After reading numerous reviews on this unit and comparing the performance of mine to that of a friend who also has it, I have to say that SONY made a slew of defective cameras and this should have been a recall. Some cameras seem to work fine, thus the good reviews. Others, and there are many many of these, shut down unexpectedly, won't work well on the 5 mega pixel setting, take terrible pictures (especially in low light) and generally aren't worth the money you paid for them.
What I soon learned was that it was running low on battery power and needed to be off most of the time or you would go through batteries like butter. Even when the camera is off and loaded with new cells it will quickly deplete itself. So you have to turn the thing off if you aren't about to shoot...this makes catching that special shot almost impossible, especially since when you do turn it on you then have to wait and wait and wait for the shutter to snap. Forget anything with low light
Dec 26, 2010 | Sony Cyber-Shot DSC-WX5 Digital Camera
When the camera is on it's base and plugged in you can view a slide show. when it is not plugged in you can not switch it on to view anything or take any pictures but the green light still works when you...
The camera's charge-couple device (CCD) within the camera must have suffered a short-circuit due to the sea water, rendering the imaging device damaged. As a result, the battery would drain pretty quick while its switched on.
Please take the camera to the nearest service center to have it repaired.
Thanks!
Sincere-One
Jul 21, 2008 | Fuji FinePix S7000 Digital Camera
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
Camera won't take pictures w/new batteries
You should replace the camera with the identical battery as recommended. REfer to your manual for the browsing of the previously taken pictures.
User manual also will tell you how to replace the battery.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 22, 2008 | Polaroid i531 Digital Camera
CAMERA WON'T TAKE PICTURES?
i don't know what age the camera is, did you try full batteries , normally it shouldn't do this it must have a defect if the batteries are not the problem..
perhaps contact the dealer see what is wrong with it..
Jan 03, 2008 | Olympus FE-180 Digital Camera
Battery empty
Are you using Lithium batteries?
I have seen other brand digital cameras do the same thing with new alkaline batteries.
Lithium batts are more expensive, but they outlast several sets of alkalines, so they actually end up costing less, compared to usage.
Dec 02, 2007 | Olympus Camedia D-540 Zoom Digital Camera
View screen sticks on view mode when switch to take picture mode
This is a button/firmware problem Canon Customer support will advise on your next move -depending on the age of the camera
Jun 28, 2007 | Canon PowerShot A75 Digital Camera
Casio QV-R40 Digital Camera Logo
129 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
