Question about Sony Handycam CCD-TRV108 Camcorder
Hi, on my camcorder the rolling pin keeps falling out because there is no lock for it. It was dropped and the piece holding in was lost. Thanks
    Genius:
  • 1,812 Answers
The pinch roller is held in place by a pressure connector and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
Panasonic kxfc225 fax
Open the machine up to see if you have drop something in it like a pencil, piece of paper or other debris. Hold it upside down and see if something falls out.
Oct 15, 2013 | Office Equipment & Supplies
How do I replace the spring in the latch door on my rn175
There are several methods for installing this little spring. My simple method. You will need 30 mm x 3 mm roll pin and a small piece of nail about 1/2 inch in length. It is very difficult to install the small factory roll pin so I use a longer one then cut off the access with Dremel. Remove the 3mm roll pin and pull out the lever discarding the broken spring. Fit the new spring on the lever using the 1/2 inch piece of nail that can pass thru the 3mm hole of the lever. The piece of nail should not stick out either side so that you can slide in the lever with short pin holding the new spring in place. Now insert the lever in place on the door and hold in position (temp pin aligned with 3mm holes in door ), lightly hammer in the long 3mm roll pin. The long roll pin will push out the temporary piece of nail holding the spring in place. Once the long roll pin is in place, cut off the extra length. Good luck
Sep 11, 2013 | Porter Cable RN175 Roofing Coil Nailer
One rusty piece of metal dropped from the middle of plastic cover. Now, the washing machine lost its sensor, it keep showing dE and peep all the time. Unable to process washing. What can I do now, please...
'dE' stands for 'door Error' indicating that there is a problem either with the lid/door lock or the lid/door locked sensor requiring a service call, sorry.That piece of metal was probably part of the door lock ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 04, 2011 | Washing Machines
The bit does not lock in place just falls out or gets stuck in the concrete. Is this normal for it to be so loose?
As the retainer shaft (part # 322550-8) wears it will begin to drop the bit. Also could be the roll pins that hold the shaft. Remove the two pins and take a look at condition. You could build up the metal with welder and grind to shape. Part is available at www.toolpartsdirect.com at a cost of about $25. Good luck with your repair.
Jul 03, 2010 | Makita HM1800 64 lb. Breaker Hammer AC/DC
It started with a loud popping from the carb and then I lost oil pressue.
the oil pump locked up and it sheared the roll pin in the dist. gear. if it still runs its because the oil pump shaft broke
the pump locked up cause the plastic timing chain gears were falling apart and some pieces got stuck in the pump
this is exactly what happened to my friends truck his did the same.pop pop no oil pressure
Mar 23, 2010 | Ford F-250 Cars & Trucks
How do i repace ignition switch on 2001 dodge grand caravan
The lock can easily be removed if you have a working key and can still turn it to the on position.
You need to remove the screws located in the bottom half of the shroud, then remove the shroud.
Locate the retainer pin ( a small square shaped metal piece) in the bottom of the lock housing) The picture below is for a reference, it is not the same lock but very similiar to yours.
While applying pressure to this pin , use your key to rotate the lock clockwise, until you feel the pin drop into the lock. At this point, you can remove the lock.
Mar 07, 2009 | 2003 Dodge Grand Caravan AWD
Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Oct 29, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Sony Handycam CCD-TRV108 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
