Question about Brother IntelliFax-2820 Laser Fax
Brother fax machine Fax-2820 MFC-7225N
I have a fax machine that i can recieve faxes on but not send as it keeps saying paper jam but there is no paper jam
    New Friend:
  • 120 Answers
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
Posted on May 09, 2008
My fax keeps saying check paper, why? I cant recieve faxes but can send them, please help.
you will need a technician to inspect the paper feed mechanism. feed rollers worn, bad sensor or paper scrap in unit. difficult for customer to get into unit.
Nov 18, 2009 | Brother MFC-970MC Plain Paper Thermal Fax
Error message says unable to print on Brother 2820. It will not answer an incoming call but will transmit a fax. Machine is in almost new condition, barely used.
when you send a fax do you get transmission report? open back to see if there might be a jam, remove cassette to see if there is a jam. if these areas are clear of paper then you have a mechanical problem and it would have to be seen by a tech
Nov 14, 2009 | Brother IntelliFax-2820 Laser Fax
We havet he brother inteli fax 2820. teh paper keeps jamming when it is tryong to feed through. We replaced the drum and we are still having the problem. IT wont feed any paper through without jamming
IF YOU ARE HANDY, WHEN YOU OPEN THE FRONT COVER YOU WILL SEE THE FUSER SECTION IT SAYS VERY HOT ON THE COVER IT COMES OUT WITH 2 SCREWS THERE MAY BE PAPER IN SIDE HOLDING DOWN A SENSOR. GOOD LUCK BROTHER SR TECH
Feb 03, 2009 | Brother IntelliFax-2820 Laser Fax
Intellifax 775
Lift up the document feeder (where the keypad is) and look for something blocking the paper path.
Jun 19, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Sending and receiving faxes on legal size paper.
There should not be a problem with TX on LGL paper. If you want to configure the machine to recieve LGL on a regular basis: Press "MENU" 1-3. Then use the up/down arrows to select LGL. "MENU", "EXIT". That should do it. Good luck!
Apr 20, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
218 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
