Question about HP Electronics - Others
I have a hp 210v pen drive when plug it to my computer but it shows access denied , in properties it shows its working
Go to start menu, click run and then type y drive letter, ex: F: click ok. and there y go...
Posted on Sep 03, 2010
Simply do rename that drive. it will work..............
Posted on Oct 31, 2012
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
Sep 06, 2013 | Computers & Internet
Iam unable to save data on pendrive
Pen drive? A USB drive? Have you formatted the drive? Do you have Admin. rights? Remove the USB drive , reboot the computer, insert the usb device, does the computer ID the device and apply a driver? Do you get a popup? Does it show in Computer? What are you trying to copy to the drive?
Jan 17, 2013 | Acer Extensa 4620 Notebook
Sir when I plug in my pen drive and try to access it, the comouter shows a message "access is denied".Please give me the solution to fix the problem
Delete the autorun.inf file on the drive.You may have to set your computer to show hidden files and system files to see that file.
Mar 01, 2011 | Computers & Internet
I can't open pen drive and it shows access is denied,
It happened because your "pendrive" contains one kind of trojan horse. Please scan by some good antivirus.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Kingston 32 GB pendrive is corrupted is ther any solution?
actually see if there is any locking hardware switch on ur drive sometimes they have one for write protection if thats not the case simply plug it in and in my computer right click and try to format if the problem persists then try restarting ur windows see if it helps other wise go www.kingston.com select ur model and trouble shoot there exactly bcoz i dont know which model u are using
Feb 20, 2009 | Computers & Internet
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
The hard disk in drive D: is not accessible
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Access Denied
This is a software issue. Sounds like it needs to be reinstalled but someone with password access.
Jan 23, 2008 | HP LaserJet 6L Printer
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
Electronics - Others Logo
293 people viewed this question
Top HP Electronics - Others Experts
Tape-Techie
Raj Patel
Are you a HP Electronics - Other Expert? Answer questions, earn points and help others
