I have just bought a samsubg Le 40 A656 LCd tv. The sound is not balanced, the right speaker is nice and clear but the left has no treble? Any ideas as to why?
  • rommelmohun May 08, 2008
    Please help me anyone?
  • 4,234 Answers
Since this is a new set, you should not spend any time on this. Return it for an exchange. Both sides should sound similar.
Posted on May 08, 2008
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Step 1:
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
Hope this helps.
Jan 21, 2013 | Kenwood KDC-215S CD Player
How to turn sound on phillips plasma 32 inch tv
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
Hi, i wanna know how i can get correct and good withe balance in many different place under sun and beside wit filters change ?thx advence
i think youre trying to ask how to create a good balance, but im not sure what you mean. theres a balance of bass to treble, and theres a balance of sound so yu dont feel too far from any speakers.
balance between bass and treble can be done with tuning the stereo and the amplifier gain.
balance so you dont feel too far from a speaker, most people get more speakers, or run a 4 channel amp to their speakers to make them louder.
Aug 17, 2010 | Car Audio & Video
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
4) the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Sound is barely audible even when volume is at 100 ... It sounds like it's all treble even though I checked the base, treble, balance, surround, etc. Should I replace the factory speakers??
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. You may be better off if the sound does work through the PC speakers, to get the TV repaired, it will be more than $100 and up
Jul 02, 2010 | Akai LCT2785TA 27 in. LCD Television
Problem with left side of all audio
Have you checked the balance foe left to right if it's full right no music will play through the speekers but you will still get the beep and other sounds like that that should be where you chand bass and treble settings along with fade center it and you should be good
Oct 04, 2009 | 2004 Nissan Sentra
How to adjust treble and bass
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
Jun 11, 2008 | Clarion RDB325D
Popping in left speaker only...
just go master volume control and check whether the left and right speaker sound is in balance that is balance must be in middle... i think this audio property may have be changed
Jan 05, 2008 | Logitech Z-2300 Computer Speakers
Televison & Video Logo
Top Televison & Video Experts
