Bought sandleford fingerprint safe, ex display model, with no master key, how do i set my fingerprint the very first time
SOURCE: sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Posted on Sep 07, 2008
johncaman
  • 201 Answers
SOURCE: lost instructions for es20 safe
This document might be of help - you'll have to determine which is your proper setup.
http://www.sentrysafe.com/pdfs/OwnersManuals/IntBarracudal.pdf
Posted on Mar 04, 2009
SOURCE: lost key to sandleford es20 safe typed in code
149 then A key
or try 149 and B key
these codes can be turned off tho if i remember in the manual...
if it works open dor... press down red button located inside the thick door kinsid the unit.. it beeps.. type new code and A
test to see if it works.
oh and throw it away
Posted on Mar 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi, I have a Sandleford genius
I found these recommendations but nothing that specifically talks about your model. I imagine one will work.
http://www.sandleford.com.au/contactus.php
149 then A key
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Posted on Jan 23, 2011
  • 190 Answers
SOURCE: I have a Sandleford ES20
stothart-
A locksmith should be able to open the safe for you. A locksmith may also be able to make a replacement key for the safe, though the cost of having a new key made may exceed the replacement cost for the safe.
Hope this helps.
Regards,
DIYpro
Posted on May 19, 2011
Need instructions to open Sandleford Digital Safe N15115 RX2009 106 485.
Hi Leanne
Try this is contacting them direct.
Sandleford Digital Safe Instructions
www.sandleford.com.au/Content/images/.../sandleford/DS200_250_300_500_230.pd...
6. Door Handle. 7. Battery Compartment. 8. Locking Bolts. 9. Reset Button. 1. 2. 3. 4. 5. 6. 7. 8. 9. 0. #. *. 3. 7. 8. 9. 21. 4. 5. 6. DIGITAL SAFE. INSTRUCTIONS ...
How to reset code on an electronic safe - YouTube
? 1:04
https://www.youtube.com/watch?v=_tqTp57YfCw May 11, 2013 - Uploaded by donutdaveyboy
How to open a digital safe without any tools or keys IN 2 SECONDS! - Duration: 2:19. Firealarm102 131,330 ...
How to open digital safe when battery is flat and key not working ...
? 1:15
https://www.youtube.com/watch?v=aqC9V7SDKdQ Nov 9, 2012 - Uploaded by khthhonl
How to open a digital safe when the battery is flat and the key does not work? This method takes less than a ...
Sandleford Digital Safe N15115 Google Search
Apr 24, 2017 | Locks & Locksmithing
How to reset the numerical code on my Sandleford Titan digital Fireproof safe No12799145
Reset digital combination to sandleford titan digital fireproof ...
www.fixya.com/support/t22206416-reset_digital_combination_sandleford
Dec 15, 2013 - reset digital combination to sandleford titan digital fireproof safe - Sentry Fireproof Safe ... someone might have known the code and changed it.
Lost instructions for sandleford E.S.20 safe - Fixya - - Forum
Dec 05, 2015 | Home Security
Crack dial combination in a Sandleford yb-500a?
As I understand it, you can use the key OR the combination. So put the key in and turn it, open the safe.
you could also try this for a bit of fun.
https://www.youtube.com/watch?v=hcYB9ceiAiY
If not, here is the link to their website and there is a contact page.
Sandleford Karbon Safes
Jul 06, 2014 | Home Security
Reset n15115 sandleford safe
i forgot my combination to my 15115 sandleford safe how do i open it
Oct 06, 2012 | Sentry Fireproof Safe
Lost keys to sandleford electronic ES20 N15115 tried to open but batteries are almost flat and just keeps beeping do i have to wait for a replacement key to open Jeff Amos
I have locked my safe I think by entering the wrong code. can you please advise how I can set a new code.... I cannot find the book that came with the safe.... thanks
May 21, 2010 | Computers & Internet
Lost instructions for es20 safe
Feb 22, 2009 | Sentry Fireproof Safe
Sandleford electronic safe es20
Aug 20, 2008 | Computers & Internet
152 people viewed this question
jasbo
jasbo
