Question about Sega Dreamcast Console
No Display I've tried everything hooking it to my Tivo, to my Vcr, to my tv, and even used a RF unit, but still no display! It turns on the cd spins but zero picture and zero sound. Not even a glitch when I turn the power on/off. My guess is that it's the adapter however I'm not sure. Can anyone shed some light?
    Problem Solver:
  • 16 Answers
The surface mounted fuse on the motherboard might be fried up if you have a technical background try to override the blown fuses by soldering a wire on it
i'll post more information about that tomorrow because my notes are at home (i'm at work hehehe)
Posted on Jun 23, 2008
  • 167 Answers
Try jiggling the cord or push it in the dreamcast a little more
Posted on Jul 02, 2008
The same problem over here -
The Dreamcast is ON - The Controler it seams to work fine (I turn the Soul Calibur game, and it worked just fine). But the display it was nothing. Only black/blue screen (depend on the TV). When I turn ON or OFF the DC console, it seams the right chanel, because of the signal - there is something, BUT it doesn't show anything...
Have a solution to this problem?
Posted on Jun 18, 2008
How can i hook up a cd player, there is only one hookup in the back and that is for the cable.
Does the TV has AV? IF it has, then you would have to look at the back of the TV again, there should be a 20 pin connector if you don't see the place where the yellow, white and red wire will fit into.
If the TV does not have AV, then follow the steps below;
  1. Get a Video cassette recorder (VCR)
  2. Use an RF wire to connect the TV to the VCR.
  3. Search the TV station to get the VCR displayed on the TV
  4. Connect an antenna to the VCR
  5. connect your CD Player to the "in" of the VCR
  6. Press the AV on the VCR and your Cd player would display
  7. By now it should be ready for use.
If you miss any step, let me know so that I can direct you further.
Best wishes.
Dec 22, 2009 | Orion STV2763 27" TV
I am trying to hook the Philips 30pf9946 up to an HD Tivo
I am wondering what you are making the connection with, If you are using s-video or composite from your tivo to your hd tv it will only produce 480i. in order to get 480p and above you will need a component video cables or better(hdmi) in order to produce the signal. You may have already known this, but I couldnt tell be the information provided. Hope this helps.
Jun 20, 2009 | Philips 30PF9946 30 in. HD-Ready Plasma...
Plays on wrong channel
ok i downloaded and read your DVR-1000 manual , this is what you will do .
While the DVD+VCR is turned off, press and hold CHANNEL (up/down) button on the front panel for about five seconds.
The unit will turn itself on and “RF 03” or “RF 04” appears on
the front panel display
Use CH ( up / down ) button on the front panel or CH ( up / down ) button on the remote control to change the RF output
channel (CH 03 or CH 04).
Turn the DVD+VCR off and then on
Set the TV to channel 3 or 4 depending on the RF
output channel you selected.
Now you can watch the DVD+VCR playback on CH3
or CH4 of your TV
PS , you should see a child lock button on the remote , if you press that button , you will disable front panel button controls so kids can't change anything , press it again to unlock that feature , it might come in handy.
Thanks for using Fix Ya .
J5
Jan 23, 2009 | GoVideo Go Video DVD/VCR Combo
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Ewr20v5 can't get it to show set up menu
zmomusa-Well for starters i'm guessing that you have an RF out to tv (where you hook up a coax cable).most units work on channel 3or 4,if you don't have RF out try going into tv through the video input (red ,white and yellow plugs) this may be easier and you will get better picture.If your not sure let me know I can help you. cooltekFeb18/08
Feb 18, 2008 | Emerson EWR20V4 DVD Recorder/VCR
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Sega Dreamcast Console Logo
333 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Iron
Iron
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
