Question about Janome Sewing Machines
The usb drivers for the janome 11000 SE will not install. says that they arent there or are corrupt. also cant uninstall when it says it will uninstall the usb.
3 Suggested Answers
  • 3 Answers
SOURCE: janome customiser 11000
When you backed up you probably only backed up documents. The executable files that make the program work are in program files and folks seldom back up program files. It was pre-installed on your pc? How weird. I believe the only thing you can do now is to go buy Customizer 11000. Check ebay and the yahoogroup sewitsforsale to see if there are any used copies. It's not an expensive program, and frankly, you don't NEED it if you have Embird, which does all Customizer does plus more.
HTH
Posted on Jul 09, 2008
  • 1564 Answers
SOURCE: usb hub broken janome 11000
It probably is. Take it in for repair.
Posted on Sep 13, 2012
Janome 11000 skipped stitches if any are even made at all
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
Mar 05, 2016 | Janome 11000 Memory Craft Special Edition...
Blue screen on janome 11000
screen is digital? may need new battery for screen power
Feb 25, 2014 | Janome America Inc 11000 Memory Craft...
Janome memory craft 11000 v2.0 now on windows xp I need to transfer this programme to a new laptop windows 7 it opend but keeps saying that I have
I believe there is a new download to make these work with windows 7.
Go here and scroll down to "customizer 11000 v 1.50" or which ever program you have.
http://content.janome.com/index.cfm/LearningCenter/Software_Updates
Sep 14, 2012 | Janome Sewing Machines
Usb hub broken janome 11000
Sep 11, 2012 | Janome Sewing Machines
I have a Janome 11000-it won't embroidery
You have to be sure you have the correct foot on the machine and that it is put on correctly. You can't use a regular foot - you need to use the embroidery foot P, which require you to remove the foot holder altogether, and put on the P.
Dec 18, 2008 | Janome Memory Craft 10000
Janome customiser 11000
HTH
May 25, 2008 | Janome Memory Craft 10000
Usb drivers
go to driverskit and download it
Feb 07, 2008 | Janome Memory Craft 10000
Formating memory
You need to format the usb stick in the machine itself, don't use a high memory one or one that has a partitioned area. 1 gigabyte or lower. You need to use the set icon on the machine and arrow through the pages to find the Format screen. Select the tab for USB device. Then click yes to the prompts, that installs the correct folder system. Now the software end,open easy design and select machine from the top toolbar, set machine type to 11000. Open a design and use the file drop down menu and select Save As, choose JEF in the file type bar, you will see a button below Save , Delete, called options, click on it, you'll find a list of machines, set it for the 11000. It is that selection that saves the design in the correct format. There are 2 jef formats, the old Jef for the previous machines and the enhanced Jef for the 11000. Now rename the design, open the flash memory menu and in the right hand pane you should see your usb flash drive, if it's the only one you have connected all well and good, if not click on each flash drive to find the correct one.You'll know which one it is,because in the window below you will see an Embf folder, open it, you must always open the Embf folder before writing a design, now some have child files inside, emb, if so open that as well , don't create a new folder it wont be read by the machine. Now write the design to the usb flash drive. Do you have a copy of the PCtools software? if so you need to download the update as it's that software that allows 2 way communication between the machine and the computer. Keep an eye on how many designs you insert into the internal memory, it isnt very big. You shouldnt need to reformat the internal memory,
Jan 08, 2008 | Janome Memory Craft 10000
Sewing Machines Logo
376 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
